kkroto
Notification Question
Fri Oct 13, 2006 2:34 am
Hi, very good job, congratulations.
I have a question, it is possible to run a external program if a device is down?
Thank you advance
winkelman
Re: Notification Question
Fri Oct 13, 2006 1:24 pm
Yes. Go to Notifiactions and create the 'execute' type notification you want. Once created, you can turn that notification on in any device you want.
kkroto
Fri Oct 13, 2006 8:50 pm
In notificatios, if I select type "execute locally or on server" then ask me a command and insert variable.
What I should put there to run an external program, for example, if node 1 is down run calc.exe
Thank you in advance for your help
kkroto
Fri Oct 13, 2006 10:13 pm
chrisd13
Mon Nov 06, 2006 7:42 pm
Apologies if this has been covered in a past topic, but could someone please provide the syntax for running an external application when a device goes down. i.e. I want a batchfile to run locally when one of my web services stops responding.
winkelman
Mon Nov 06, 2006 7:55 pm
You'll find your answer two (or three) items above your own, within this same topic!
Just play with it a little.
chrisd13
Tue Nov 07, 2006 11:38 am
Ok, thought there might be some sort of syntax for the command, obviously not ;) ok thanks.
Users browsing this forum: No registered users and 3 guests
