MUM Europe 2020
Adonis3a
the dude- I cant add any pakage to the file
Thu Dec 08, 2016 2:52 pm
hello everyone
i try to add pakage and some picture in dude file but i cant
+ menu is not enable is look like disable or have some problem
thanks
M3nt0san
Re: the dude- I cant add any pakage to the file
Sun Feb 26, 2017 8:44 pm
I'm having the same problem. Have you managed to sort it out?
nemke
Mon Mar 06, 2017 1:18 am
Same here...
Dude 6.38.3 I upload svg file and MIB on dude server on right file path, but I don't see them in MIB list and images.I try to reboot but probem continue.
Dude is instaled SD/dude-data. And here are file upload.
dadoremix
Sat Mar 11, 2017 4:23 pm
i try to upgrade via DUDE .. other mikrotik routerOS devices
but cant upload in files DUDE .. files..
watching https://wiki.mikrotik.com/wiki/Manual:U ... to-upgrade
I dont have + in files to add routeros-mipsbe-6.38.5.npk
any help?
msatter
Sat Mar 11, 2017 5:38 pm
Did you try the upload button?
Thing changed when updates went to the RAM instead of the flash so no more "+" button. The Wiki should be updated on this when there is time.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46.x / Winbox 3.21 / MikroTik APP 1.3.10
Android device owners, use https://github.com/M66B/NetGuard/releases (no root required)
dadoremix
Sat Mar 11, 2017 7:12 pm
i try upload file with winbox..
in flash and in SD card
cant see in dude
so i cant auto mass upgrade
nemke
Tue Mar 21, 2017 7:22 pm
I update Dude to 6.38.5 problem stay... Any file uploaded to server can't be used. Try with UPLOAD button and also to drop file....same.
amt
Long time Member
Long time Member
Fri Apr 28, 2017 12:36 pm
I solve this problem like this;
I enter the dude server installed device and add the packages to the under dude/files/
kiralee
Thu Jun 15, 2017 5:16 am
Same here...
Hi Nemke
you need to add the file which you need into the "(data-path)/files/" directory." via Winbox
You can check the full wiki in this page : https://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Files
But I think the upload function is not friendly.
You only can upload the file to the main folder , then push it in to "(data-path)/files/"
I hope this information can help you.
Kira
savagedavid
Trainer
Trainer
Wed May 02, 2018 8:13 am
Solved: I managed to work around the problem by creating a folder structure on my local PC e.g. /dude/files/[filename}
Then drag the entire file structure to Winbox. This added the package in the correct place and it appears in Dude monitor under Packages.
savagedavid
MTCE+T (MikroTik Certified Everything + Trainer)
MikroTik support and training in South Africa
http://www.mikrotiksa.com
david [at] mikrotiksa dot com
Users browsing this forum: No registered users and 14 guests
