rtacheny
Adding Winbox Tool
Mon Jan 09, 2017 6:45 pm
I am currently working on setting up a RB750Gr3 as a dude server and am having trouble setting up winbox as a tool. I have used the dude before, however this was already in there. This is how I added the tool:
disk1/files/winbox.exe [Device.FirstAddress][Device.UserName] [Device.Password]
Given that this isn't x86, I'm not sure if this can even work, however I'm assuming that it would just point my PC I am working from to the directory and that it should be able to launch the exe through there. I am getting an error that the file cannot be located. If this is something that can be done, I'm assuming my file path is incorrect. Any help would be appreciated.
mbfound
Re: Adding Winbox Tool
Mon Jan 09, 2017 8:49 pm
Have the same issue.
Says "execution failed (command: "path-to-winbox" ip-address username password) 2:the system cannot find the specified file."
On our old dude 3.6 - winbox just ran from any pc.
mbfound
Mon Jan 09, 2017 9:01 pm
Hi, might've solved it. Try:
D:\winbox.exe [Device.FirstAddress] [Admin.Name] [Admin.Password]
Do not use " " and make sure theres a space between [] []
rtacheny
Mon Jan 09, 2017 10:20 pm
Unfortunately, still nothing.
normis
Tue Jan 10, 2017 9:56 am
You have to point the Dude client to a folder on the Windows PC. You have "/disk1" in there, this does not seem like a Windows path. You must use something like "C:\\"
rtacheny
Tue Jan 10, 2017 9:46 pm
Thanks Normis, this clears it up. What I will have to do is inform other users that they must store their mikrotik.exe in the exact same directory that the command specifies on each and every computer that they want to be able to use this feature in.
tomasi
Thu Jan 12, 2017 2:19 pm
Here still doesn't work
I've created the Winbox link in 6.38 inside Dude > Tools menu pointing the link to C:\Tools\winbox.exe [Device.FirstAddress][Device.UserName] [Device.Password], but it shows "unknown" status
This way, in the map, when I right click any device, go to Tools > Winbox, nothing happens.
PaulsMT
Thu Jan 12, 2017 2:40 pm
You can also save winbox.exe file on the Windows desktop, and use path variables:
%HOMEPATH%\Desktop\winbox.exe [Device.FirstAddress] [Device.UserName] "[Device.Password]"
tomasi - please try these steps:
Open Tools => [+] sign => in "Command" add your Winbox path, for Windows users use:
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Tools
tomasi
Thu Jan 12, 2017 3:18 pm
Thank you, PaulsMT
I was doing it wrong: creating the Winbox item via Dude > Tools menu inside winbox of x86 server.
Now I found the Tools menu in the Dude Windows Client.
I followed your instruction and it worked perfectly.
Now it keeps the parameters:
Type: execute
Command: C:\Tools\winbox.exe "[Device.FirstAddress]" "[Device.UserName]" "[Device.Password]"
Thanks! :D
sparker
Wed Jan 18, 2017 8:25 am
Please do so that you can select multiple types of devices Tools
Sorry for my English.
PaulsMT
Wed Jan 18, 2017 8:27 am
You mean to allow specific tool for multiple devices ?
sparker
Wed Jan 18, 2017 8:36 am
PaulsMT
Thu Jan 19, 2017 11:39 am
At the moment you can also specify device type. By this way you can allow tools only for specific device group.
Hotz1
Sun Jan 22, 2017 10:34 am
Same here. I was trying to create the tool from within Winbox, using the cool new "Dude" GUI item.
Principal, Engineering
Cape Ann Communications, Inc.
Gloucester, MA, USA
scampbell
Trainer
Trainer
Thu May 11, 2017 1:28 am
I found one site (W10 Desktop) required additional parentheses (as below) - not sure why but it sorted a file not found error. 8) Windows ???? :lol:
"%HOMEPATH%\Desktop\winbox.exe" [Device.FirstAddress] "[Device.UserName]" "[Device.Password]"
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, MTCEWE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
tomasi
Tue May 30, 2017 11:18 pm
I'm using the absolute path here:
it's working perfectly. :)
Trisc
Sat Nov 04, 2017 2:22 pm
I am running Dude on a CHR. We upgraded to 6.40.4 and now winbox does not open automatically
Adding the path to Winbox in tools using the method described in this thread does not work - only a window containing the winbox app opens - and if I change the path to winbox in one Dude client it affects to all clients connected to the Dude server.
eriitguy
Mon Nov 06, 2017 9:10 am
Trisc,
May you try to copy winbox.exe to the Dude client folder?
In such case you probably might be able to add Winbox tool without full path.
If this will work, all you Dude client should do the same.
Thank you!
Trisc
Mon Nov 06, 2017 11:09 am
Many thanks - that solved it!
mitc0nkick5a55
Tue Jan 02, 2018 7:01 am
I am trying to follow the same instructions to add the Winbox tool by adding winbox.exe to the dude client folder under programs (x86). Could you post where you put winbox.exe, and also what you put in the dude server under tools to bring up winbox and make it work?
normis
Tue Jan 02, 2018 8:34 am
Have you tried reading the topic from the beginning? There are multiple posts that answer your questions right here on this page
honzam
Wed Jan 03, 2018 9:40 am
After many years of using dude 3.6 we switched to new dude
We running dude 6.40.5 on rb1100AHx4 dude edition. Starting winbox 3.11 is slow. With dude 3.6 start winbox very faster.
Is it possible to optimize it?
LAN, FTTx, Wireless. ISP operator
MathewTSJ
Wed May 23, 2018 8:50 am
this works for me:
C:\..................\winbox.exe [Device.UserName] "[Device.Password]"
maxsaf
Wed May 30, 2018 5:45 pm
That may be useful too
C:\Tools\winbox.exe [Device.FirstAddress] [Admin.Name] [Admin.Password]
Will open winbox with your own dude login and password instead of device login and password with different rights
HaQs
Wed May 30, 2018 7:04 pm
OK but add execution winbox.exe user pass
Is not very good solution (password in plain text)
When winbox wil be integrated in dude client or support hashed password when it is executed from dude ?
JimmyNyholm
Wed Jun 06, 2018 1:36 pm
Or better yet. Support external rest api call for geting current password from other system. Dude is loged in with one type of user that should not be used by personell from say Support or other personel from say NOC.
jcutrer
Wed Jan 02, 2019 10:56 pm
To clearly answer your question, winbox.exe should be placed in
C:\Program Files (x86)\Dude\
and your Tools|Winbox settings command should read...
winbox.exe [Device.FirstAddress] [Device.UserName] [Device.Password]
Users browsing this forum: YaCy [Bot] and 11 guests
