slech
Long time Member
Long time Member
Dude v6 - Missing features from earlier versions
Fri May 26, 2017 8:11 pm
Currently, only Dude v6 is under development. But some of users still use Dude v3.6 or 4.0beta3.
In order to help developers to develop new features and users to make a decision about migration we will collect a list of features missing in Dude v6 which present in earlier versions.
As Dude v6 is under active development, our list will become more and more short.
Missing features from earlier versions:
Logs
In Dude v6 we can't create multiple logs instances, like it was in earlier versions.
Feature request - Multiple logs instances
Web server
In Dude v6, at the moment, we can use access to the Dude using Webfig.
Feature request - Full featured Web access
Outages
Notes - In Dude v6 is not possible to add a Notes to the Outages.
Feature request - Add Notes to Outages
Functions - execute
In Dude v6, at the moment execute function is not supported.
Maps - Export
In Dude v6 automatic map export was removed.
Export Map interval
New features appeared in Dude v6:
Added - AES encryption method for snmp v3
Agents - Now any RouterOS device can be used as The Dude agent
Added - Dude server now supports spectral scan up to 7Ghz.
Added support for The Dude configuration from CLI
Added - Option to pass dude login credentials as variables for custom login tools.
arm - added Dude server support
The Dude admins now rely on ROS users. User requires dude policy to connect to server
Added comment option for servers in client loader window
Added - Check-box in dude client loader settings to allow upgrade/downgrade without prompting user each time
Added 10G link type - Will be added by default only for new installations.
Added option to run dude client from shortcut in secure mode by adding argument "--secure".
Auto discovery tasks are now separated between network maps.
SMTP authentication and tls options added!
Added db vacuuming option
Added progress indicator to import/export/vacuuming
Full list of changes you can see in Dude v6 changelog
Related forum topics
New features in Dude RC
sorry for my english
gianmaxfactor
Re: Dude v6 - Missing features from earlier versions
Thu Nov 16, 2017 8:27 am
I miss the "Execute" function that on Dude v4 allowed me to launch Windows batch commands and get the output to use it into another user-defined function as the one below
Function : check_poe
Code: if((array_element(execute("checkpoe.bat",device_property("FirstAddress"),"E:\\Batch\\"),1)="deny"),(array_element(execute("checkpoe.bat",device_property("FirstAddress"),"E:\\Batch\\"),1)),"false")
eriitguy
Thu Nov 16, 2017 12:08 pm
Hello, gianmaxfactor!
The Dude/Notifications
Execute locally - Run command on the local Windows machine (where Dude viewer runs), can pass variables
Execute on server - Run command on the Dude server machine, can pass variables
The_Dude_v6/Notifications
Execute on server - Executes ROS script on The Dude server host when notification is triggered. In "Command:" field you need to write script in RouterOS scripting syntax.
May a Execute locally be used to solve this? It will work only when Dude client is running and will be executed on Windows where it working.
In case you need only Execute on server a Windows version of Dude v6 server should be released and you may create a Feature request for this.
It may be helpfully in such case to rename Execute on server to one more appropriate, because they are different:
1. Execute on server - Windows
2. Execute on server - ROS
Thank you!
gianmaxfactor
Thu Nov 16, 2017 12:24 pm
Hi dear, thank you for your kind answer!
I am not so expert, but I don't think it is the same.
The old "execute" function was able to catch the output of the batch so that you could treat it as an array of string and get the one in the position you specified.
The execute notification you suggest seems to be just a launcher for a batch (eventually passing parameters) but it is not meant to catch the output of the batch and use it in Dude.
Am i right?
Thanks a lot
Gian
gianmaxfactor
Fri Nov 17, 2017 6:17 pm
I miss also another feature.
In the Dude v4 I remember that you could set snmp settings for each network map indipendently.
Sometimes I want to completely stop the snmp checks on all the device of a specific map, and before I could do it through the map setting (snmp set to no-snmp), but now it seems not possible to do it.
eriitguy
Sat Nov 18, 2017 5:09 pm
Am i right?
Thanks a lot
Gian
gianmaxfactor, thank you for observation!
It seems that I didn't carefully read your post. I found function you mentioned, in Dude v4.0beta3:
Description: executes program, returns array of three elements - return code, standard output, standard error. return code is -1 if error occurs. Only first parameter mandatory. First paramerter - command, second - parameters, third - path, forth - input string to pass to program, fifth - timeout in seconds (default 5.0)
Motivation of removing maybe same as I have mentioned in previous post. We may ask Mikrotik support for explanation.
Thank you!
eriitguy
Sat Nov 18, 2017 5:29 pm
gianmaxfactor, I have verified now old versions of Dude, v3.6 and v4.0beta3. None of them have SNMP settings on Map level:
In such case we may create a feature request for your idea.
Thank you!
gianmaxfactor
Mon Nov 20, 2017 5:51 pm
Thank you eriitguy for your verification!
I'm sorry I am wrong (I certainly do not remember well), maybe I selected all the hosts on a map and then edited with a one-click the snmp configuration for all of them.
Anyway I am glad that it could be an idea worthy of a feature request ! But do not ask me how to insert one :wink:
Thank you again
Gian
eriitguy
Tue Nov 21, 2017 9:16 am
Thank you again
Gian
Gian,
Feature request - Default SNMP profile for the Map
Thank you!
eriitguy
Mon Dec 04, 2017 8:56 am
Hello!
It seems that one more feature was removed from Dude v6: Export Map interval
Thank you!
gianmaxfactor
Tue Dec 05, 2017 6:26 pm
Oh yes, it would be very useful if they implement it again. You can virtually use any external program (and why not, with linux too) and catch its output do define an up/down state.
Regards
Gian
slech
Long time Member
Long time Member
Mon Jan 01, 2018 10:48 am
Users browsing this forum: Google [Bot] and 11 guests
