  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
awarfield
Re: Probe Thread
Thu Jun 06, 2013 4:59 am
Hi, This is my label for
It just lists the printer count for colour and black
Sharp MFD
[Device.Name]
Black: [oid("1.3.6.1.4.1.2385.1.1.19.2.1.3.5.4.61")]
Colour: [oid("1.3.6.1.4.1.2385.1.1.19.2.1.3.5.4.63")]
[Device.ServicesDown]
Samsung Printers
[Device.Name]
Black: [oid("1.3.6.1.2.1.43.10.2.1.4.1.1 min 1.3.6.1.4.1.236.11.5.11.83.1.1.1.1.20")]
HP 1320 (dont know if it works for other HP printers)
[Device.Name]
Black: [oid("1.3.6.1.2.1.43.10.2.1.4.1.1")]
dazm
Re: Probe Thread
Mon Jun 10, 2013 8:31 am
Unswer for you Sebastian.
I decided to show how it works for me in pictures :)
I reworked some funtions:
search 2nd ip-address in the array of addresses.
The auxiliary function, which determines the availability of ip-addresses.
Listing of that function below:
Code: if((array_element(ping(Device2Address()),0)=-1),"false",array_element(ping(Device2Address()),0)+1)
My Probes
Listing of probe config below:
Name of probe: ping2
Type: Function
Error: if (ping2s()<>"false",(if (ping2s()-1 < 500, "", concatenate("RTT_", ping2s(), "_ms"))),"timeout")
Value: array_element(ping(Device2Address()),0)
Unit: ms
And how it works
p.s. I find one mistake, on my sub-funtions, and corrected it. Now all worked fine.
CypherBit
Re: Probe Thread
Thu Jun 13, 2013 11:49 am
We run a couple of SQL Servers, and I found it useful to track the amount of memory that the SQLserver process was consuming - in this case I was looking for sqlsrvr.exe in the list of running processes, so to look for and plot the memory consumption for other processes, simply change "sqlservr.exe" for something else such as "System Idle Process".
Any idea how one would use this if we only have one central SQL server with multiple instances. It appears one is picked by Dude, but I need to follow all four.
homerkaro
Re: Probe Thread
Fri Jun 21, 2013 3:31 pm
Hi!
I'm trying to create a probe to check if a program runs on my server or not.
First i'd like to test it with the notepad.exe so i created this probe:
Type: function
Available: if(array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"),"NOTEPAD.EXE")>0, 1, -1)
Error: if(array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"),"NOTEPAD.EXE")>0, "", "NOTEPAD.EXE not detected by SNMP probe")
Value: 1 (or anything else, is purely for charting purposes and I return 1 if the service is running)
Unit: running (or whatever you want to call the above values)
Rate: none
But its not working. I'm getting unreachable error message. The snmp is configured well because i can get other properties of my computer (cpu,hdd, memory).
What do i do wrong?
Thanks!
Daniek
lebowski
Re: Probe Thread
Mon Jun 24, 2013 5:01 pm
Hi Homerkaro, FYI, on the available line the -1 will always return true. Make a function and call it from a probe to make it work better.
The function;
Description: find the array index to notepad or return False
Code: if(array_size(oid_column("1.3.6.1.2.1.25.4.2.1.2",10,0)), array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2",10,0),"notepad.exe"),"False")
The Probe;
Type: Function
Available: find_notepad()<>"False"
Error: if(find_notepad()<>"False",if(find_notepad()<>-1, "", "Warning: notepad not running"), "Failed to read running programs")
Note: Windows 7 returns -1 if the program is not running. The available line works since -1 is "true" and when the SNMP section does not exist the function returns "False" (The probe will not automatically install on devices that do not have the OID for programs)
I suspect some operating systems will give you cpu utilization for a single process, maybe you could graph that.
Lebowski.
ephillips
Re: Probe Thread
Thu Jun 27, 2013 7:49 pm
I am new to The Dude and was trying to get a set up to see if a specific scm product and a sql server is running. Is it at all possible to do either of these tasks?
amokkatmt
Re: Probe Thread
Thu Oct 31, 2013 11:13 pm
Hello. How can I count active interfaces? Please see screenshots. How can I count those with status "up" ? This is EPON OLT, so interface count is dynamic and their states are dynamic too.
Thank you for any help.
itsupportschulen
Re: Probe Thread
Wed Nov 20, 2013 11:38 pm
Hello together,
here are some probes of mine of the last few days:
temperature of Fujitsu Siemens Server if you have Serverview installed:
Available: if(string_size(oid("1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.0")), 1, 0)
Error: if(oid("1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.0")<10, concatenate("ACHTUNG Temperatur = ", oid("1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.0"), "° C"), "")
Value: oid("1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.0")
Unit: °C
some oids of other temperatures with which you can create some probes like the shown one:
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.1 (SYS1)
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.2 (SYS2)
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.3 (SYS3)
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.4 (CPU)
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.5 (MEM_A)
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.6 (MEM_B)
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.7 (MEM_C)
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.8 (PSU1_Inlet)
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.9 (PSU2_Inlet)
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.10 (PSU1)
1.3.6.1.4.1.231.2.10.2.2.5.2.1.1.11.0.11 (PSU2)
Works on a FSC TX150 S8.
Available: if(string_size(oid("1.3.6.1.4.1.232.3.1.3.0")), 1, 0)
Error: if(oid("1.3.6.1.4.1.232.3.1.3.0")>2,if(oid("1.3.6.1.4.1.232.3.1.3.0")=3,"degrade",if(oid("1.3.6.1.4.1.232.3.1.3.0")=4,"failure","")),"")
Value:
Unit:
Checks the RAID on HP Servers, (this return a number: 2=ok, 3=degradate, 4=failure)
http://pandorafms.com/index.php?sec=Lib ... id_PUI=261
Available: if(string_size(oid("1.3.6.1.4.1.231.2.10.2.11.2.1.0")), 1, 0)
Error: if(oid("1.3.6.1.4.1.231.2.10.2.11.2.1.0")>1,if(oid("1.3.6.1.4.1.231.2.10.2.11.2.1.0")=2,"degrade",if(oid("1.3.6.1.4.1.231.2.10.2.11.2.1.0")=3,"error",if(oid("1.3.6.1.4.1.231.2.10.2.11.2.1.0")=4,"fail",if(oid("1.3.6.1.4.1.231.2.10.2.11.2.1.0")=5,"unknown","")))),"")
Value:
Unit:
(This OID indicates the Global state, not only RAID disk failure. 1=OK, 2=Degradate,3=Error, 4= Failure)
HTH
Sebastian
PLEASE open source the code or let us pay for The Dude!
kaipr
Re: Probe Thread
Tue Dec 03, 2013 3:52 pm
Hello there,
since the update for Dude isn't comming for years, and I need to check on IPv6 devices as well as on IPv4, I would like to consult you guys, if you have an idea how to implement IPv6 ping probe. For start, I have put the IPv6 address into the user parameter1 of the device, and have made a tool for hand checking:
ping [Device.CustomField1]
What I would like to achieve, is a service, which has a custom probe, using a function which evaluetes the output of the ping command. Any ideas for a simplistic solution here?
Thank you, i'm sure this would help a lot of people.
Vlasta
m2hewitt
Re: Probe Thread
Mon Jan 06, 2014 3:27 pm
Hi guys
i have a probes for check the memory usage over application, for example:
And they has working OK, but i need configure alarm if this they exceed a memory consumption. how can i do?
Regrds,
rextended
Re: Probe Thread
Fri Mar 28, 2014 2:13 pm
I made one probe for check the status of ethernet or sfp port (connected or not):
http://forum.mikrotik.com/viewtopic.php ... 08#p418008
I'm Italian, not English. Sorry for my imperfect grammar.
lebowski
Re: Probe Thread
Mon Apr 07, 2014 11:02 pm
If the dude is set to auto discover and you use -1 for false in the available line the probe will install on every device.
AVAILABLE: if((oid("1.3.6.1.2.1.25.2.3.1.6.1")/oid("1.3.6.1.2.1.25.2.3.1.5.1"))*100>0, 1, -1)
The available line is to determine if the OID exists on the device in question but negative one is not false in the available line...
It is way better to create a function that returns a value or False. Then call that function from a probe.
Function
disk03test
if(array_size(oid_column("1.3.6.1.2.1.25.2.3.1.6",10,5)),round((oid("1.3.6.1.2.1.25.2.3.1.6.3",10,5)/oid("1.3.6.1.2.1.25.2.3.1.5.3",10,5))*100),"False")
Another function to grabs the name of the disk then if it is in error the drive letter or unix name can be returned in the error message.
Funciton
disk03name
oid("1.3.6.1.2.1.25.2.3.1.3.3" ,10,5)
So now in the probe the available line is simplified to test for "False".
The error line can also detect if the probe can't read the disk or if the disk is full...
The Probe
Available: disk03test() <> "False"
Error: if(disk03test()<>"False",if(disk03test() < 90, "", concatenate("Warning: ", disk03name(), " is ", disk03test(),"%")), "Failed read 3rd disk")
Value: disk03test()
unit: %
HTH,
Lebowski
guisalazar
Re: Probe Thread
Tue Jun 03, 2014 3:40 pm
anyone know how to probe the status of an PPTP server?
nhathaitrieu6
Re: Probe Thread
Fri Jun 27, 2014 1:26 pm
Hello
Someone maybe with an Hp Procurve 5406 switch ?? Im searching for CPU and Memory OID's
Patek Philippe Ref. 5271P mua đồng hồ casio chính hãng ở đâu là phiên bản trang sức cao cấp của Ref. 5270 và một số màu đen trổi
itsupportschulen
Re: Probe Thread
Thu Aug 28, 2014 12:12 am
maybe someone :wink: here it comes:
Probe name : cpu_procurve
Type: Function
Available: if(string_size(oid("1.3.6.1.4.1.11.2.14.11.5.1.9.6.1.0")), 1, 0)
Error: if(oid("1.3.6.1.4.1.11.2.14.11.5.1.9.6.1.0")>80, concatenate("ATTENTION CPU usage =", cpu_procurve(), "%"), "")
Value: oid("1.3.6.1.4.1.11.2.14.11.5.1.9.6.1.0")
Unit: %
Probe name : temp_ProCurve_2 > 45 C
Type: Function
Available: if(string_size(oid("1.3.6.1.2.1.99.1.1.1.4.17")), 1, 0)
Error: if(oid("1.3.6.1.2.1.99.1.1.1.4.17")<45, "", concatenate("ATTENTION Temperature = ", oid("1.3.6.1.2.1.99.1.1.1.4.17"), "° C"))
Value: oid("1.3.6.1.2.1.99.1.1.1.4.17
Unit: °C
These probes works on most HP ProCurves Switches with CPU und Temperature sensors/feature.
HTH
Sebastian
WinWisp
Re: Probe Thread
Thu Sep 04, 2014 1:42 am
Here is our ntp probe, tested and working on our ubuntu 12.04 ntpd servers
For ease of copy/paste, here is the 'Send' string:
\x1b\00000000000000000000000000000000000000000000000
Islander
Re: Probe Thread
Sat Sep 13, 2014 2:01 pm
This is probably very simple, but I've been struggling for a few days now.
I'm running web-based VLC on a number of Raspberry Pi's (I'm an entertainment technician at a large leisure site, and these Pi's play music in various areas), and am using The Dude to alert me if any of the Pi's go down by way of using the Ping probe - works fine.
The web-based VLC has an XML status page, which has an assortment of information such as the state of the player ('playing', 'stopped'), volume, track being played etc. I'd really like a couple of probes to read/parse this xml, and a) alert me if a player isn't in the state 'playing', and b) display information on my map such as track playing, volume.
I've tried modifying the http probe, but with little luck, and I'm not sure where else to look. Any advice?
lebowski
Re: Probe Thread
Mon Sep 15, 2014 7:46 pm
The HTTP probe will look for a word on the resulting page but displaying that word is problematic. The right way to do this is to grab the xml with an execute function and return you own result, then use that in a label for the device.
There are quite a few posts around asking how to use the execute function so search for them and read those first but here are the steps...
Install a text browser into your dude server(linx is linux based there has to be a windows one), put it in the root of the C: drive or at least in a folder with out spaces like c:\tools\linx.exe. That will hopefully simplify parameters
Create a batch job that runs linx and then use something like grep to parse the xml... There is a grep for windows as well. (note this is off the cuff so it is not exact)
Then the execute statement will be like;
execute("pstate.bat", "device.Firstaddress"," c:\\tools\")
The lines of the batch job will be something like
linx %1/webpagename.xml > tempxml.txt
if grep playing tempxml.txt echo playing
if grep stopped tempxml.txt echo stopped
if grep track tempxml.txt echo track
(%1 will be seen as device.firstaddress in the batch job)
Grep is probably not a very good thing to parse xml and maybe you will need to create a custom VB script or use Expect to give better results but you should be able to build something.
A good troubleshooting tip is to get the results of each step to display through a device label so you are certain it is working as planned.
You can modify the label refresh interval on the map settings but I am not certain how effective this will be to keep the label accurate.
HTH,
Lebowski
altecsole
Re: Probe Thread
Thu Sep 25, 2014 10:44 pm
Many thanks, this worked for our Windows NTP servers too.
altecsole
Re: Probe Thread
Fri Oct 10, 2014 6:27 pm
The function to display on device label UserName of user logged on a Windows Host.
You must know that:
1. There is no SNMP oid to check user logged on Windows host.
2. You can retreive UserName of logged user using WMI.
3. The Dude has not WMI support.
4. The Dude can run any executable file and retreive it's result using build in function execute.
5. It is easy to access any of WMI functions using simple VBScript.
Let put it all together and create sample function to retreive UserName of user logged on a Windows Host using WMI and put it on device label.
Thank you so much for this post. I'd been wrestling with something similar for several hours. Very much appreciated.
berny81
Re: Probe Thread
Mon Oct 13, 2014 5:53 pm
I would like to start a thread that has custom Probe example on it. My hope is not only to further my Knowledge but hopefully help others with this great software.
Here are a few I have made.
Cisco CPU
Type: Function
Available: if(oid("1.3.6.1.4.1.9.2.1.58.0")>0, 1, -1)
Error: ""
Value: oid("1.3.6.1.4.1.9.2.1.58.0")
Unit: % of cpu load
APC PDU LOAD
Type:Function
Available:if(oid("1.3.6.1.4.1.318.1.1.12.2.3.1.1.2.1")>0, 1, -1)
Error: if(oid("1.3.6.1.4.1.318.1.1.12.2.3.1.1.2.1")>0, "", "No Load")
Value: oid("1.3.6.1.4.1.318.1.1.12.2.3.1.1.2.1")
Unit: Load amps in decimal
Hi All,
I am new to the Dude and i want to create a function then use it in a probe for example if the OID temp of a cisco switch goes above 65 degree to send an email notification indicating the actual temperature with a message "Please check server room temp"
I checked the example above but quite honestly i am not getting the programing language how it works.
per ex: what is >0, 1, -1)
>0, "", "No Load")
Can someone please explain to me with a simple example how to read the command line ?
Also what is confusing is that > 65 means lower than !
Thanks in advance
berny81
Re: Probe Thread
Mon Oct 13, 2014 6:03 pm
Cisco CPU
Type: Function
Error: ""
Unit: % of cpu load
APC PDU LOAD
Type:Function
Hi All,
>0, "", "No Load")
Thanks in advance
lebowski
Re: Probe Thread
Tue Oct 14, 2014 1:30 am
Make a file "who.vbs"
Set objNetwork = CreateObject("Wscript.Network")
Wscript.Echo objNetwork.UserName
Execute who.vbs in your label... I will finish this tomorrow...
THIS is crap... there are quite a few reasons why getting the username of the logged in machine is a pain. Running an escalated program is not too bad but windows management instrumentation console fails to run when integrated into a batch job called by the dude. Mostly I can't understand why the execute function is saying error when I can run the program on the command line... So I don't have a solution.
Here is an interesting program that works but when I have the dude run it, it fails.
WMIC /NODE: 192.168.1.1 COMPUTERSYSTEM GET USERNAME /format:list - Note you would need to add a user/pass to escalate privileges to read other machines. But executing this in a batch job results in error and I can't figure out what to do to fix that.
If you could get the above command to run from a batch job you could later replace 192.168.1.1 with %1 then
WMIC /NODE: %1 COMPUTERSYSTEM GET USERNAME /format:list /user:priv /pass:priv
You could execute test.bat device.firstaddress but this is CRUD to work on and doesn't work. I will revisit later.
Lebowski
jdurrett
Re: Probe Thread
Fri Dec 12, 2014 12:23 am
Greetings. I am on day 2 of using "TheDude" and I'm confused on the purpose of Services/Polls/SNMP/MIB's/Functions.
In a nutshell, I have all the MIB's imported, can SNMPWalk the device (Microwave Radio) and now I want to (SolarWinds terminology only perhaps) "Poll" the device for the values returned by the OID's SNMPWalk shows them...but the Polling service does'nt return the value of an OID...its just comparing it to a known value and giving Yes or No. I want VALUES reported not Yes/No. Thats what ping is for.
From reading forum posts, it seems the method to the madness is that I have to SNMPwalk to get OID's, then I have to create a Function to be responsible for getting the information, then I have to create a Polling Service - Not Mind you Based on Type SNMP, but Function, and then I must put in code to each section to get the value that SNMPWalk showed me without hesitation.
Oh, and I tried to use an example found and I'm getting parsing errors for reasons unknown.
Can someone please enlighten me On how an OID becomes an actual monitored value for a device?
lebowski
Re: Probe Thread
Fri Dec 12, 2014 6:49 pm
How the dude works is already documented to death. You just need to keep reading till you understand what your doing but I will help by trying to describe some of the details. An OID becomes a graphed value buy using it in a probe and adding a probe to a device as a service. The simplest way to graph a value is by sticking the OID in the Value: of a probe. So click on probes click + to add a new one, put test in the name, switch the type to function which will add some more fields. Note; This is not a function in the functions panel. It means the probe will function like a tool and can call functions or use OIDs directly.
Leave everything else alone but put your OID in the Value, as follows;
Value: oid("1.3.6.1.4.1.318.1.1.1.2.2.2.0", 10 ,5)
Add the test probe to a device by selecting services and clicking + and make sure history is enabled "graph poll times".
When I build a probe I create a function and use it on a label before building a probe. Open the function panel click+ type the name and put some code in the function, place the function in the appearance of a device by right clicking then select appearance in the "label" put your function in brackets and if you get a value you have created your function correctly if you get parse error you have to examine your function. Here is a function that returns the temperature from an APC UPS.
code: oid("1.3.6.1.4.1.318.1.1.1.2.2.2.0", 10 ,5)
So now I can modify the appearance of a UPS and add the function to the label. Note click the down arrow on the right to enable a custom label
Label: [ups_bat_temp()]
This will cause the device to show that oid in the label. Custom labels can be configured on individual devices and map wide but not on device types (bummer).
Now go to your test probe and in the value line replace oid("1.3.6.1.4.1.318.1.1.1.2.2.2.0", 10 ,5) with ups_battery_temp()
The available line is for auto discovery (don't use it till you understand the implications), the error line is for notifications so you can work on those later.
HTH
Lebowski
edit one incorrect statement
alekstef
Re: Probe Thread
Fri Apr 24, 2015 4:45 pm
Does anybody know if it is possible to query a unit through its XML API using The Dude? I'm not very into all this kind of stuff, and would like to know if it is even possible, before I spend a lot of time trying to make it work :-)
serhio
Re: Probe Thread
Fri May 15, 2015 11:55 am
After few hours of investigating protocol and analyzing WireShark traces, I made my TFTP server probe:
<?xml version="1.0" ?>
<dude version="4.0beta3">
 <Probe>
  <sys-type>13</sys-type>
  <sys-id>2039720</sys-id>
  <sys-name>tftp</sys-name>
  <typeID>6</typeID>
  <defaultPort>69</defaultPort>
  <tcpSend1>\00\01dude.txt\00octet\00</tcpSend1>
  <tcpReceive1>^.*</tcpReceive1>
 </Probe>
Key is in this string \00\01dude.txt\00octet\00. Here is explanation:
1. You need 2 bytes OpCode. 00 01 is read request.
2. We will ask for some file, like dude.txt. This string must be null terminated, so we have \00 after name.
3. We should specify transfer mode. We will use binary mode or octet, ending will binary zero or \00.
4. If anything return (even something like Access denied to dude.txt), TFTP works. There fore, just put ^. as return.
Cheers,
Srdjan
itsupportschulen
Re: Probe Thread
Wed Sep 09, 2015 12:37 am
Hello together,
I search for a way to compare the DNS-Name, or NETBIOS, or SNMP-Systemname of a device with the [Device.Name] in one probe. If equal, it's ok, otherwise there should be an error. Anyone an idea?
Background:
We have all our Client-Computer with DNS Names in the Dude (with DNS Lookup: name to adress). Sometimes it happens that a client seems to be "up", but if you look carefully, you see that this is not the client which should be "probed" because the DNS Lookup isn't working perfect.
Maybe someone has an idea how to monitor such DNS-Errors ;-)
thanks
Sebastian
R4id0
Re:
Mon Nov 16, 2015 9:38 am
Check if a certain program is running on a Windows system ('OUTLOOK.EXE' in this example):
Type: function
Available: if(array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"),"OUTLOOK.EXE")>0, 1, -1)
Error: if(array_find(oid_column("1.3.6.1.2.1.25.4.2.1.2"),"OUTLOOK.EXE")>0, "", "OUTLOOK.EXE not detected by SNMP probe")
Rate: none
This of course requires the SNMP agent is running and configured properly on the Windows system.
This works great but is it possible to monitor if an application is in "Not responding" state?
lebowski
Re: Re:
Tue Nov 17, 2015 11:47 pm
Applications in the not responding state do not show up in Window 7 SNMP view as not responding... They show as running which sucks. I had a not responding program, found it in the registry then found the run index and checked all entries of the run index so I doubt it is updated in SNMP. Maybe build a tool that checks the program and use execute to handle the query.
Lebowski
hanscker
Re: Probe Thread
Wed Nov 18, 2015 2:44 pm
I'm starting to create some functions and I'm really frustasted with an issue with the device_property and if statement.
The current type of the device is "OPE" and I created the following probe for testing:
if(device_property("Type")="DES",device_property("Type"),"error")
and I got the result "OPE", but i should get "error" as result.
Could you tell me if it is a bug or i'm wrong?
I'm using version 4.0 beta 3
jbhainsworth
Re: Probe Thread
Wed Nov 25, 2015 6:24 pm
New to the forum and not sure if this is the right place to post a question.
I am trying to adjust the probes so that the value is rounded to only 2 decimal places. Mainly to reduce the device image from constantly changing sizes.
jbhainsworth
jbhainsworth
Re: Probe Thread
Mon Nov 30, 2015 8:30 pm
jbhainsworth
I got this corrected, It took me realizing how the label was created and the sub components that created it.
HiltonT
Re: Probe Thread
Sat Jan 30, 2016 2:57 am
Any more info on what you did here as this has been annoying me for a while, too.
Regards,
Hilton Travis
JamesMcCarthy
Re: Probe Thread
Sun Apr 24, 2016 10:56 pm
Hi I was wondering if anyone could help me. I would like to return the value of the {Device.ServicesDownCount] as a percentage of the overall services down to display in each devices appearance. Is this possible and how would I go about doing this. Would be good to get it to return an error if over a certain percentage
navrik
Re: Probe Thread
Tue May 24, 2016 11:03 am
Hi!
I'm trying to start monitor port states on our switches in Dude. So, using some guides from this topic i created Function like this:
Type: Function
Agent: Default
Available: if(oid("1.3.6.1.2.1.2.2.1.8.1")=1)
Error: if(oid("1.3.6.1.2.1.2.2.1.8.1")=2, "", concatenate("Link to ",  oid("1.3.6.1.2.1.31.1.1.1.18.1"), " is down"))
So this function doesn't work properly - always stay in down position, seems like port state is down. However, the port description is taken from the switch correctly by oid("1.3.6.1.2.1.31.1.1.1.18.1"):
snmpwalk 172.31.100.1 1.3.6.1.2.1.31.1.1.1.18.1
iso.3.6.1.2.1.31.1.1.1.18.1 = STRING: "some hardware"
But if i try to use snmpwalk, i see correct state (1 - UP, 2 - Down):
snmpwalk 172.31.100.1 1.3.6.1.2.1.2.2.1.8.1
iso.3.6.1.2.1.2.2.1.8.1 = INTEGER: 1
Maybe somebody can help me - where i can start looking for the problem, or there is an error?
lebowski
Re: Probe Thread
Wed Jun 01, 2016 7:55 pm
In the error line any value returned is considered an error. You must return "" if you are not in an error state. In your case you are returning a value so it is in an error state.
if(device_property("Type")="DES","","error")
lebowski
Re: Probe Thread
Wed Jun 01, 2016 8:05 pm
Hi!
place this on the device label [oid("1.3.6.1.2.1.2.2.1.8.1")]
Use the exact match that is displayed in your device label to check the error...
Error: if(oid("1.3.6.1.2.1.2.2.1.8.1")="down (2)", "", concatenate("Link to ", oid("1.3.6.1.2.1.31.1.1.1.18.1"), " is down"))
navrik
Re: Probe Thread
Thu Jun 02, 2016 9:50 am
Hi!
Perhaps I have misunderstood something. However, a survey on the state of oid I see only numbers (1 or 2) without the words up/down:
link on 1st port is up
link on 15th port is down
snmpwalk 172.31.100.1 1.3.6.1.2.1.2.2.1.8.15
iso.3.6.1.2.1.2.2.1.8.15 = INTEGER: 2
Accordingly, their writing and in function without "up/down". So this function get correct description by oid port, the state - no.
lebowski
Re: Probe Thread
Mon Jun 13, 2016 4:40 pm
Hi!
Does this work?
Error: if(oid("1.3.6.1.2.1.2.2.1.8.1")="INTEGER: 2", "", concatenate("Link to ",  oid("1.3.6.1.2.1.31.1.1.1.18.1"), " is down"))
Or does this work? with 2 in quotes...
Error: if(oid("1.3.6.1.2.1.2.2.1.8.1")="2", "", concatenate("Link to ",  oid("1.3.6.1.2.1.31.1.1.1.18.1"), " is down"))
You could also try oid_raw to grab values.
Error: if(oid_raw("1.3.6.1.2.1.2.2.1.8.1")="2", "", concatenate("Link to ",  oid("1.3.6.1.2.1.31.1.1.1.18.1"), " is down"))
I don't know exactly how links are handled inside the program
navrik
Re: Probe Thread
Fri Jul 22, 2016 1:58 pm
Does this work?
All this 3 variants doesn't work. Tried last builds include 6.36. Already end versions of why it has worked for 45 minutes and broke without the possibility of recover.
lebowski
Re: Probe Thread
Fri Jul 22, 2016 7:06 pm
navrik; Place the following on the device label;
What exactly is displayed on the device? use that in your comparison.
hengst
Re: Probe Thread
Sat Dec 10, 2016 4:39 pm
How to write a probe / function for a NON SNMP device in Dude,
The plan :
I have a telecom cabinet for example with a "door sensor"
i would like to send (Hex?) code to an IP:port ( TCP )
to a dumb sensor/device that gives back an Hex with 1 bit changed when a door/sensor is open/closed.
code i would like to send : 7e303230303031343230313030303041410d
i need (to convert) the received (Hex?) code.
as i need bit number XX to be 0 or 1 ( door open or door closed )
Found the way to send correct command from the Dude TCP probe. "send" field.
i came to this when i made from the original hex
this in the dude tcp probe "Send" field.
\x7e\x30\x32\x30\x30\x30\x31\x34\x32\x30\x31\x30\x30\x30\x30\x41\x41\x0d
after clicking "apply"
the dude converted to
~02000142010000AA\r
now when entering " ^. " in the receive field.
and do a packet scan. i see the command send, and i get the correct answer back .
meaning :
~020001420000274257AE140000000000000000000000000000000041C8000041C800000141C80000000000010001F2 ( door open )
~020001420000274257AE140000000000000000000000000000000041C8000041C800000141C80000000000010000F2 ( door closed , looks like last bit changed from 1 to 0 )
now , how do i get my right bit ( door open/closed ) from that ?
Update ! , found the ( simple ) way to extract the right bit. direct from "receive" section.
~[0-9A-Fa-f]{91}0.* seems to work for me, if i enter that in the "receive" window of the tcp probe. and it works.
( read and learn about wildcards : http://wordmvp.com/FAQs/General/UsingWildcards.htm )
( to test your "RegEx" code you can use http://www.regexr.com/ )
Now i would like to create a function to do this , and be able to generate different errors parsed from the received data string.
1 bit is for "door" sensor
1 bit is for "water" sensor
1 bit is for "power" sensor
how can help with that ?
lebowski
Re: Probe Thread
Fri Jan 06, 2017 5:00 pm
(Future) request :
Look at execute, you can call other programs/scripts and batch jobs.
hengst
Re: Probe Thread
Fri Jan 27, 2017 10:26 am
(Future) request :
Lebowski , i found direct way to send the right command from default tcp probe. ( see my edited post ) . can you / or someone give some light on how to write the function to parse the data that comes back ?
lebowski
Re: Probe Thread
Fri Feb 03, 2017 4:40 pm
Can you put a regex that matches door closed in the receive? ~[0-9A-Fa-f]+0F2$ or ~[0-9A-Fa-f]+1F2$
Then you could at least make multiple probes with different "returns" so if the door is closed the tcp probe is true and then when ever the door is open, false.
Get the program regex designer from rad software and you can test your expressions much faster.
If you can put a TCP probe in a "Function" then you can use IF and make a much better probe but I can't figure out the syntax. Functions were meant to be called from a probe.
Lebowski
hengst
Re: Probe Thread
Fri Feb 03, 2017 4:54 pm
the Probe is already working for the door sensor.
the received regex =
i retrieve that last bit from this regex by entering
~[0-9A-Fa-f]{91}0.*
in the "receive" window of the probe. this works very well and simple.
i can do that for different "bit" alarms with several probes, but i think this may come as a DoS attack on the dump device/
ideal would be to send 1 request. and parse several "bit" alarms from 1 received regex.
for this i think it needs some little script/function. but that is little to difficult for me at the moment.
hengst
Re: Probe Thread
Fri Feb 03, 2017 5:07 pm
so the Big question would be ;
can you put a TCP probe in a "Function"
or
can you use a "Function" in or with a TCP probe
right ?
i think if plausible it would make the Dude VERY useful out of the box.
lebowski
Re: Probe Thread
Fri Feb 03, 2017 5:13 pm
~[0-9A-Fa-f]{91}0.*
Seriously nice work figuring that all out.
If your TCP Probe has ~[0-9A-Fa-f]+0F2$ of course it should show "up" when the door is shut.
The regex ~[0-9A-Fa-f]{91}0.* doesn't work in regex designer but... If that was an OID it would be trivial, it looks like creating it as an execute is going to be way better in the long run.
=http://stackoverflow.com/questions/244 ... Python TCP
Lebowski
lebowski
Re: Probe Thread
Fri Feb 03, 2017 5:16 pm
Call any type of probe from a function would be a great addition.
L
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
Users browsing this forum: No registered users and 15 guests
