gcser
Dude 6 backup fails (6.40.5)
Wed Nov 15, 2017 1:01 pm
Hi Guys,
I have a dude install. When I export the dude database (/dude export-db backup-file=dude), the export does not generate any file, instead of an autosupot.rif file is created.
The log doesn't contains any error message.
I have no idea, what could be the problem.
Has anybody experienced this problem?
jarda
Re: Dude 6 backup fails (6.40.5)
Wed Nov 15, 2017 3:16 pm
What device is it? Is there enough space? Storage format? User rights? Use .tgz suffix for file name.
gcser
Wed Nov 15, 2017 3:20 pm
It is an Alix 1C ITX board, x86 architecture.
Disk is almost empty, I have 1GB free space. The system backup runs without error, only the dude export fails.
jarda
Wed Nov 15, 2017 3:24 pm
Hard to guess. Try it again and after that create a supout.rif file and send it to support as error report.
eriitguy
Wed Nov 15, 2017 3:34 pm
Hello, gcser!
In my case all working fine:
Thank you!
gcser
Wed Nov 15, 2017 3:39 pm
In my case, the backup starts without error, but before it finishing, I get the autosupout file.
Thank you for your help, I send the rif to the support...
Users browsing this forum: No registered users and 21 guests
