drakabelkabeldrag
Can Not Connect Via The Dude After Installation
Mon Dec 11, 2017 10:11 am
I'm having a problem where The Dude does not allow my connection as directly after install. I tried using putty, winbox's telnet and The Dude client software. All of them deny my connection. I saw a sollution where you have to change the 'full' permission group to include 'dude' but I do not get this option in the winbox client. I have tried using 2 The Dude versions (6.40.5 and 6.41rc61).
slech
Long time Member
Long time Member
Re: Can Not Connect Via The Dude After Installation
Mon Dec 11, 2017 9:41 pm
Hello, drakabelkabeldrag!
You may try to follow guide from the Wiki: The_Dude_v6/First_use
Be sure that account which is used for login have at least dude and read permissions as described in the WIki: The_Dude_v6/Admins
Thank you!
sorry for my english
drakabelkabeldrag
Tue Dec 12, 2017 11:26 am
I did follow the guide but there is no option to include the 'dude' permission when I try to change it in winbox so I still get locked out of The Dude
Shadeofspirit
Tue Dec 12, 2017 11:36 am
what version of dude do you use and what version of client? what kind of error message do you have?
MTCNA, MTCWE
eriitguy
Tue Dec 12, 2017 1:45 pm
drakabelkabeldrag,
Dude v6 is a ROS package which should be installed into ROS: Manual:The_Dude_v6/Installation.
Did you install Dude on your ROS?
Thank you!
Users browsing this forum: No registered users and 9 guests
