jerico99
Cisco Interfaces No Longer Work in Dude GUI
Tue Feb 06, 2018 2:20 am
When I upgraded the Dude to 6.37.5, none of my cisco interface status's are displaying correctly any more.
SNMP seems to populate interfaces for everything 'except' cisco devices.
benjamimgois
Re: Cisco Interfaces No Longer Work in Dude GUI
Fri Mar 09, 2018 3:20 pm
I had the same problem when i migrated from 3.6 to 6.x version. I solve the problem changing from SNMP v1 to SNMP v2c on the device settings.
Telecomunications Engineer
Cisco CCNP, CCNA, CCDP, CCDA
maxsaf
Fri Mar 09, 2018 7:30 pm
I have the same problem with Netonix switches.
viewtopic.php?f=8&t=131614
esquirrel
Mon Mar 12, 2018 5:55 am
Sorry for asking such a beginners question..
Are there similar programs that work on Linux through SNMP, that can configure both Mikrotik's and other vendors's (Cisco's) products?
Or does "the Dude" program run under Wine?
jacobtoupe
Trainer
Trainer
Mon Mar 12, 2018 3:32 pm
Hi
Dude v6 has two parts.
The server and the client part. The server version runs on RouterOS (on CHR, CCR, RB1100Dx4, RB750Gr3, and CRS326). It's the client part which runs on Windows. It should also runs on wine since winbox runs on wine and dude client isn't so far from winbox.
Regards
Jacob
jerico99
Mon Mar 12, 2018 7:05 pm
Thanks for the response. I'll try using v2.
The other thing that doesn't work in any later versions is radius authentication to dude using chapv2. As soon as I upgrade to any other newer version, it reverts to pap when I try to authenticate.
Users browsing this forum: No registered users and 13 guests
