neutronlaser
Just make The Dude for mipsbe
Thu Feb 08, 2018 1:35 am
Come on, just make The Dude for mipsbe.
jarda
Re: Just make The Dude for mipsbe
Sat Feb 10, 2018 3:25 pm
On which device you would like to run the dude?
ste
Sat Feb 10, 2018 8:33 pm
There is a special device for The Dude. Why not just use it before asking MT to do porting work.
jarda
Sat Feb 10, 2018 9:15 pm
There are much more devices than that to run the dude...
neutronlaser
Sun Feb 11, 2018 12:04 am
Ordered 2x HEX as I saw they can run on those.
ste
Sun Feb 11, 2018 5:41 am
Only for small networks. Was not stable for us. Rb1100AHX4 is the device to run the Dude.
chechito
Sun Feb 11, 2018 6:49 am
remember to use micro sd to host the dude files
chechito
Sun Feb 11, 2018 7:00 am
is not about stability, you must be aware of computational power of rb750gr3 cpu, its a little dual core like a cheap smartphone cpu you must size the dude accordingly:
For rb750gr3
maximum of 40 services monitoring and maximum 4 days of raw value data storage and maximum 75 mega-byte database size
For rb1100ahx4
maximum of 80 services and maximum 4 days of raw value data storage and maximum 150 mega-byte database size
For ccr1036
maximum of 160 services and maximum 4 days of raw value data storage and maximum 300 mega-byte database size
Anything beyond that you will have not good results
beyond that you need a separate x86 device to host the dude
for big networks multiple virtualized instances of the dude will be needed, ssd storage etc etc
always keep the dude database size under 500mega-byte to keep good performance
ste
Sun Feb 11, 2018 9:19 am
For rb750gr3
For rb1100ahx4
For ccr1036
I guess we had stability problem with HEX as ram was not enough. Runs for 2 weeks and then suddenly died. Just had to hard reboot. No problem since switched to rb1100ahx4. Rock solid now.
dadoremix
Sun Feb 11, 2018 1:42 pm
How via dude
Manage 120 device
Change pass on 120 device? Can dude that?
Backup 120 device via dude?
If can, how? Tnx
mmandrino
Mon Feb 19, 2018 12:08 pm
How via dude
Manage 120 device
If can, how? Tnx
As far as I know, you will need to do some scripting from dude, or other router to do this.
normis
Mon Feb 19, 2018 3:34 pm
How via dude
Manage 120 device
If can, how? Tnx
You can use TR-069 ACS to do that. Dude is for monitoring, not for mass configuration.
Users browsing this forum: No registered users and 2 guests
