Maclaren
10g Link Mikrotik router
Thu Mar 01, 2018 2:09 pm
Dear All,
I need a 10g link from somewhere, can you suggest me the cheapest mikrotik router?
TIA
JohnKennedy
Re: 10g Link Mikrotik router
Sat Mar 03, 2018 9:44 am
There are many, check ccr1036 8g 2s+
This will suffice your need.
vicky58911
Sat Mar 03, 2018 9:46 am
Check ccr1009, it has one port for 10g if I am not wrong.
Maclaren
Sat Mar 03, 2018 10:10 am
Aru u sure ccr1009 supports 10g?
vicky58911
Sat Mar 03, 2018 10:17 am
Maclaren
Sat Mar 03, 2018 10:49 am
Thank vicky58911
It supports 10g, but I think its expensive! Any other cheaper option
vicky58911
Sat Mar 03, 2018 11:19 am
Please check ccr1036-8g-2s+
But I think its expensive too
pe1chl
Sat Mar 03, 2018 11:54 am
Spoiled brat! You get a 10G router for the price that we could not even get a 10M network card 25 years ago,
and still you think it is expensive. I suggest you shop at Cisco or Juniper instead...
Maclaren
Sat Mar 03, 2018 12:05 pm
Dear vicky58911,
Thanks a lot for your support, actually I am here in Pakistan, Asia for a short business trip and want a mikrotik router with a 10g link! I have gone through many options and I think CCR1009-8G-1S+ is the best option for me. One problem is I am here for the first time and just got to know that amazon does not ship here. If you know any reliable online outlet here please let me know?
Second thing is if you use mikrotik quite often kindly let me know how is the performance of ccr1009? Is it smooth enough to use for a beginner because I wont be here after basic installation.
vicky58911
Sat Mar 03, 2018 12:11 pm
Dear vicky58911,
You can find the distributor in Asia from the mikrotik website. Also I think this vendor supplies to your destination https://w11stop.com/mikrotik
Regarding mikrotik performance I must say Mikrotik has made my life very easy, all their products are good.
Maclaren
Dear vicky58911,
You can find the distributor in Asia from the mikrotik website. Also I think this vendor supplies to your destination http://www.w11stop.com/mikrotik
Is it easy to use for a beginner?
Maclaren
Sat Mar 03, 2018 12:12 pm
You just need to have basic networking knowledge and you are good to go? Can that be said for mikrotik
vicky58911
Sat Mar 03, 2018 12:14 pm
Yes mikrotik is easy to use
Maclaren
Sat Mar 03, 2018 12:15 pm
Thanks a lot dear
Users browsing this forum: No registered users and 11 guests
