jonesjk
How do I add MIBs to the dude
Tue Jan 09, 2007 8:36 pm
I am new to the dude how do I add mibs to the dude
winkelman
Wed Jan 10, 2007 1:55 pm
Go to the 'Files' section and load the mib there...
synergyuk
Re: How do I add MIBs to the dude
Wed Feb 01, 2017 4:46 pm
Do we upload this file from inside The Dude or Winbox?
I have been trying to drag and drop the MIB into the files list in The Dude and it isn't working, there also isn't an upload option?
msatter
Wed Feb 01, 2017 5:01 pm
The wiki states: Your custom uploaded mibs/images/etc need to be stored in: "(data-path)/files/" directory AND After file upload it will take some time for mibs/images to become available on client side for use in labels/maps/etc.
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Files
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.47 / Winbox 3.24 / MikroTik APP 1.3.14
synergyuk
Wed Feb 01, 2017 5:17 pm
Thanks, I have uploaded the file now.
How long do you have to wait? Hours or days?
rextended
Wed Feb 01, 2017 8:20 pm
1 minute
rename the file from "*.mib" to "*-mib.txt" for work
I'm Italian, not English. Sorry for my imperfect grammar.
msatter
Wed Feb 01, 2017 8:40 pm
That bit of renaming the files I omly could deduct from the screen picture shown in the Wiki after the explaination by Rextended. It would be nice if one could in the Wiki the exact way of working to import the files correctly.
Running:
synergyuk
Thu Feb 02, 2017 2:05 pm
It's still not working, I dropped 4x MIBS in over 10 hours ago and its not picked up any of them. I have even restarted The Dude service several times
synergyuk
Thu Feb 02, 2017 2:22 pm
I cannot drag and drop them into "dude/file/default/mibs"
I get error message "Couln't change file <UBNT-AirMAX-MIB.txt> - action failed (6)"
msatter
Thu Feb 02, 2017 2:27 pm
Did you use the Dude interface as can be seen in the Wiki page I linked too?
I have never used it myself so I can't be absolutely certain on this. You have to put it in the "(data-path)/files/" and that is lower in the directory list. To me you have put it in the Flash directory so they have to be in the /dude/files/ directory.
Running:
msatter
Fri Feb 10, 2017 1:37 pm
I assume it has worked by now!?
Running:
eriitguy
Tue Jul 04, 2017 9:26 am
It seems that folder
dude/files/default/mibs
is read-only.
1. I have created folder
dude/files/mibs/liebert
and uploaded all mibs files there.
2. Renamed files from .MIB to .MIB.txt
And now I can see all mibs inside MIB nodes in Dude.
Thank you!
russman
Tue Apr 17, 2018 6:11 pm
I just brought up a fresh dude CHR server on 6.42 and I'm having the same problem. Using WinSCP it says the file system is read only, can't do it in winbox ether. The directory we add them to is /dude/files/default/mibs correct?
Update: I see you leave out default in the last post now.
So its uploaded but after 45min I don't see the file in in but I don't see the Siklu appearing under the Modules tab.
sergioaugusto
Tue Aug 14, 2018 3:13 am
I'm using a UIAS-RM RB3011, I tried to send the UBNT-UniFi-MIB.txt file to the dude / files / default / mibs folder using WinSCP and says it's read-only.
How to send a mib file to dude? I tried in ways following wiki, forum and I did not succeed in any.
slech
Long time Member
Long time Member
Sun Aug 19, 2018 9:16 am
sergioaugusto,
As described in the posts above,
is read-only folder.
For your mibs you should create a separate folder, for example:
dude/files/mibs
and put there your files.
Thank you!
sorry for my english
nubip
Thu Jan 30, 2020 1:46 pm
One question.. i upload de MIB file and can view on Dude the entire mib node of the module, all parameters explained.. all ok. But, when i make a snmp-walk over the device that uses this MIB, the values of this module are not visible: i can see IF,SNMP,RFC module values..but not the specific module values of this MIB. Is it possible that Dude let be capable of loading the MIB but then not being able to read these values ​​from the device?
Users browsing this forum: JosephSlater007 and 10 guests
