MrMaxim
Could not installed on hAP AC2
Wed Mar 28, 2018 9:34 am
Yesterday I bought Mikrotik hAP AC2 to use the Dude server.
I uploaded dude-6.40.6-arm.npk to "disk1", rebooted the device, but no effect.
No Dude in packages, no Dude in menu.
in CLI:
[admin] > /dude
bad command name dude (line 1 column 2)
I did try to upload to flash/ and to flash/skins and reboot. The result was same.
Please give me advice how to install The Dude serverside.
Thank you
Maxim
jarda
Re: Could not installed on hAP AC2
Wed Mar 28, 2018 10:12 am
This is correct behaviour. Disk is ramdisk. Flash has only 16MB. You need to use external storage connected to USB for dude.
MrMaxim
Wed Mar 28, 2018 10:26 pm
I connected usb flash drive 16Gb, format it to ext3 . Upload on it *.npk file. reboot device. And get the same result :(
I was using topic "Manual:The Dude v6/The Dude server on hEX RB750Gr3"
Can you explain me step by step installation process .
jarda
Re: Could not installed on hAP AC2  [SOLVED]
Thu Mar 29, 2018 3:11 pm
The npk file should be put in the router not in the external flash. Just drag and drop it into winbox and do not care where it goes to. Then reboot. After the boot see the log.
MrMaxim
Thu Mar 29, 2018 4:16 pm
Thank you ! Its worked !
jarda
Sat Mar 31, 2018 4:31 pm
The easiest things just work. Enjoy the dude!
jacksonx2000
Tue Oct 27, 2020 3:09 am
I got same error in hAP AC2.
Followed the best answer
After reboot, same error message "not enough space for upgrade"
AZ82
Thu Jan 14, 2021 10:42 am
Also can not install the Dude.
I have attached 4gb usb stick, formatted it to ext3, put dude npk to router, but after reboot got the same error that not enough space. Please advice!
Users browsing this forum: No registered users and 7 guests
