eddieb
add 2 lines in graphs together ?
Wed May 02, 2018 8:44 am
I have graphs of connected wifi cients per AP.
I want to add the values togehter into one line in a graph to see the total of connected wifi users in my network.
Any suggestions in how to add those values together ?
regards,
Eddie
Running 6.45.6 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, ipsec/l2tp roadwarrior, dhcpd, dns), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc), RB931-2nD, RB951, RB750GL ,RB2011UAS-RM, CHR running dude (CHR running in VirtualBox on OSX)
jarda
Re: add 2 lines in graphs together ?
Wed May 02, 2018 1:15 pm
If the graphs have the same y-axis metrics then they overlap automatically in the graph page of the device. I use that for voltage and temperature graphs...
eddieb
Wed May 02, 2018 2:05 pm
The 2 lines in one graph is not a problem, but I want to stack the values to see a maximum in the graph ...
chechito
Wed May 02, 2018 4:15 pm
i have used the dude chart function to add many sources on one graphic to get the graphic you mention
eddieb
Wed May 02, 2018 4:31 pm
The screenshot below shows a graph with 2 lines from separate devices. I want to stack them, not to show them side by side ... I can not find a wy to do that ...
So 1 line with the total of both devices added together.
chechito
Wed May 02, 2018 4:41 pm
in chart data sources you have to create a new one adding the multiple snmp values you already have using oid codes () and +
once you have that data source created you can add it to a chart
sorry not having more precise information I no longer have access to those implementations
eddieb
Wed May 02, 2018 7:08 pm
The 2 OID are from different devices ...
I know that would be the direction to look into, but I can not find how to add snmp oid from 2 (or more) devices into 1 datasource ...
eddieb
Wed May 02, 2018 10:26 pm
Found it ...
not that hard after all, tnx for the suggestions.
create a datasource for device "none" and put some function code inside
create a graph for this new datasource
chechito
Thu May 03, 2018 12:07 am
Found it ...
I'm glad you did it, those graphics are very useful
Users browsing this forum: No registered users and 6 guests
