fibernet4u
IPGovernor: Free Cloudbased Mikrotik Network Uptime Monitoring Tool for LAN & WAN host
Mon Jun 04, 2018 11:47 am
http://api.ipgovernor.com/api
New Version Video Tutorial:
https://www.youtube.com/watch?v=JLqko0VXL8c
Dear Community Friends,
We mikrotik group of friends were working to build a dedicated Mikrotik based uptime network monitoring tool for out Mikrotik Community. & Today we happily launching our BETA version of Cloud monitoring system for our Greate Mikrotik community.
IPGovernor is an online tool which closly work with Mikrotik netwatch feature & notify you via email when there is downtime in your local network or your WAN host/site/or port goes down.
Feature:
* Get notified your downtime via email instantly.
* Pre-configured auto scripts available for each host...which simply need to copy paste to your mikrotik netwatch entry.
* Grouping Feature for logically downtime for your unamnaged switch.
* Site wise seggrigation of your hosts, to easily identified the area.
* Parent child linking feature to know from exactly the isolation is happend. (Minimized your local troubleshooting time.)
* Logging & Charts to review downtime of your individual host...for better grip on infra.
* Alert contacts to notify multiple people for particular host or down or uptime.
* Api key control to each account for security.
**Many more...
Encouraging you to kindly signup and utilize the benefit. Please be in touch incase you need any support.
Signup: http://api.ipgovernor.com/api/
Support: ipgovernor@gmail.com
Note: Please note this cloud based tool is only for Mikrotik Router Community only.
WAN Host every minute Latency & Downtime details of the week
Best regards,
fibernet4u
Re: IPGovernor: Free Cloudbased Mikrotik Network Uptime Monitoring Tool for LAN & WAN host
Mon Jun 04, 2018 3:24 pm
Wow!
This was superb boost on high number of signup on our cloud. Thank You! Guys, just to highlight some of functionality still in developement thats the reason we launch for community. Please email to to us incase of any issue..
I Love being Mikrotik User & wishing you on board to take advantage of Netwatch tool functionality by Mikrotik..
SimonK
Wed Jun 06, 2018 2:53 pm
Hi @fibernet4u,
i would love to participate. got about 95 MK routers
How does is it work?
Will the system need access directly to the router from WAN or can the Router contact the system?
/Simon
fibernet4u
Wed Jun 06, 2018 6:46 pm
Thank You! Simon for you interest and Signup.
We have already emailed you with instruction to setup you network and alerts.
Answer is No
Its a passive tool which recived information from your network for LAN. And for any WAN host.. our cloud directly check for the uptime.
SimonK
Fri Jun 08, 2018 9:06 am
Hi Again,
Well i tried adding one router, i think its way to time consuming to add 95 router.
Im running Librenms internal, so adding new units is automated.
Maybe u should reconsider a more automated way to add units.
/Simon
fibernet4u
Fri Jun 08, 2018 9:49 am
Dear Simon,
Sure! Currently There is Copy option available against each entry. Meanwhile you can use that to create new host in more faster way.
Please ping me via Skype id: IPGovernor at outlook Dot com
fibernet4u
Sun Jun 10, 2018 10:35 am
Dear All,
Basis on the request we have added basic video tutorial for setting up your network monitoring on IPGovernor tool.
Video Tutorial link: https://www.youtube.com/watch?v=0FBze-zulpo
Note: Now we have started adding mikrotik & tool related videos on this channel.
Genkun
Mon Jun 11, 2018 11:25 am
Watching the Video now. Lets hope it goes smoothly for the setup. I did not see any import command?
We have an EMCO monitoring which can export to csv format. There are over a thousand entries so an import would be ideal. Even if the information on first import is minimal, name and IP address. Can always add more information later.
fibernet4u
Mon Jun 11, 2018 11:31 am
Dear Genkun,
Yes, we are in process or bulk import option. meanwhile you may use copy option for any created host to create new entry in fastes way.
BrettH
Tue Jun 12, 2018 1:16 pm
Would it be correct to suggest that this is based upon the PHP Server Monitor, an open-source PHP-based server monitor licensed under GPLv3? It doesn't appear that you've provided any credit to the contributors of the original project, which isn't required as you're not distributing the source-code, but would still be considered courteous regardless - Just my two cents.
Also it seems that you're actively working toward monetising this platform, which does go against the pretence of "Free" that you've floated here as a means of justifying what is otherwise a gratuitous advert. Could you clarify why you need a pricing page if this project isn't commercial in nature?
Honestly, this kinda comes across as bait-and-switch advertising... Getting free advertising for a free platform and charging for it later on.
fibernet4u
Tue Jun 12, 2018 2:29 pm
We are not monetizing it.
xbliss
Thu Aug 22, 2019 2:44 pm
Just signed up to test drive on Home network.
Dont see the verification email coming through
xbliss
Tue Nov 26, 2019 3:13 pm
Previous Post
Users browsing this forum: Bing [Bot] and 14 guests
