magnuskarlsson
The dude on RB760iGS
Mon Jun 25, 2018 9:31 am
Hello
Cant get the dude to install on my RB760iGS.
I am not really sure of witch npk file i should use.
pukkita
Trainer
Trainer
Re: The dude on RB760iGS
Mon Jun 25, 2018 3:23 pm
Hex S or RB760iGS is MMIPS, dude package should be for MMIPS and match the installed ROS version, e.g. if you have 6.40.8 installed: Dude 6.40.8 MMIPS
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
chechito
Mon Jun 25, 2018 4:58 pm
msatter
Mon Jun 25, 2018 5:03 pm
Hex S or RB760iGS is MMIPS, dude package should be for MMIPS Dude 6.40.8 MMIPS
I am surprised by this because how do you know which version of RouterOS is installed on the 760iGS?
For all three versions of RouterOS there is a separate version of Dude which can be found at this page: https://mikrotik.com/download and you have to search for MMIPS
And follow the instructions in the posting above (chechito).
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta / Winbox 3.20 / MikroTik APP 1.3.4
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
magnuskarlsson
Wed Jun 27, 2018 1:05 pm
Tank's for the help.
i hade the wrong version now it is up and running.
pukkita
Trainer
Trainer
Mon Jul 09, 2018 1:40 pm
Good catch, edited.
Users browsing this forum: No registered users and 4 guests
