flaviobhz
Add images to device Dude 6.40.8
Thu Jul 19, 2018 12:33 am
I have a RB 750gr3Hex v6.40.8, firmware: 3.41, with Dude.
As I add or modify the device images, this version does not have the button to add the images. Would you have another way to add the images?
Adicionar imagens nas device Dude 6.40.8
Tenho uma RB 750gr3Hex v6.40.8, firmware: 3.41, com Dude.
Como adiciono ou modificar as imagens das device, nessa versão não tem o botão para adicionar as imagens. Teria outra forma de adicionar as imagens?
dasiu
Trainer
Trainer
Re: Add images to device Dude 6.40.8
Thu Jul 19, 2018 12:41 pm
Upload the file with Winbox/FTP/SCP/anything... to the RouterOS filesystem (to the dude directory - I prefer to create a new subdirectory, as the default images are in the "static" directory you can't change).
flaviobhz
Thu Jul 19, 2018 5:35 pm
Ok, work it out, thanks.
ebertyrodrigues
Sun Aug 05, 2018 8:04 pm
Tambem, gostaria de personalizar meu dude, mas não consegui e não encontrei nada que funcionasse.
Users browsing this forum: No registered users and 11 guests
