JimmyNyholm
Move device to Submap.
Fri Dec 07, 2018 10:29 am
Hi I wonder if there is a smart way moving devices from main map to a newly created submap without having to "delete and recreate" them. IE Some drag and drop functionality somewhere or a property on the object that i have not yet discovered?
Please advice. What is the current best practise in this situation?
Hoov
Re: Move device to Submap.
Sat Dec 08, 2018 12:18 am
If there is a way, I have not found it. Good luck. I just delete a device from one map and recreate it on another.
villageworker
Sat Dec 08, 2018 4:45 am
Select a device or devices on a map, copy, open new map, paste.
JimmyNyholm
Mon Dec 10, 2018 7:46 am
Thanks I didn't think of that but:
This will create a new device making statistic readings / Historical Data of all device data not being there. Right?
What I am about to do now this "work around" will suffice. But there should be a move function as from dude's standpoint it would be the same device an no historical data would be lost in the process.
Yours /J
JimmyNyholm
Mon Dec 10, 2018 11:34 am
Copy, Paste (as in ctrl-c ctrl-v doesn't work in dude client windows.
Context menu on right mousebutton doesn't show this as an alternative either. AM I missing something?
Yes. The buttons in the window work. But there probably is a bug or not assigned os standard shortcust to the button.
Thanks again for the suggestion it will suffice this time....
villageworker
Mon Dec 10, 2018 3:37 pm
Yes, your are right. Copying is only available on th user Iinterface button and yes we lose the history on the copy.
I agree with you that an 'alias' type of concept for map elements would be beneficial.
Note to Mikrotik decision makers. PLEASE KEEP IMPROVING DUDE.
Masyanich
Thu Jan 24, 2019 9:05 am
can you please add the screenshot of it?
i cant find this function :(
villageworker
Thu Jan 24, 2019 9:20 am
Masyanich
Thu Jan 24, 2019 9:36 am
villageworker, thanks a lot!
mohannad
Thu Jan 24, 2019 2:02 pm
True Same To Me
Users browsing this forum: No registered users and 16 guests
