jmay
Storing POE Port status from Netonix
Thu Dec 13, 2018 7:33 pm
Anyone figure out a way to use the dude to store port information from a Netonix POE Switch? I'd like to have history so when one dies (which happens a lot) I can have access to which ports had POE on and whether they were 24v or 48v. I figure I can graph which works and gives me a 24 or 48 graph to view, but the problem comes in with a port that is set to off, I then get a probe error showing down which I don't really want.
Heres the oid for port 1 for example
1.3.6.1.4.1.46242.5.1.2.1
Return values are 24V 48V and Off
Anyone doing anything like this?
WirelessRudy
Re: Storing POE Port status from Netonix
Tue Dec 01, 2020 7:09 pm
Did you ever found your answer?
I would like to know now, I am setting up Dude and have some 8 Netonix switches in my network. I would like to draw as much info from them I can that is useful.
But its hard to find the needed oid's
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
Users browsing this forum: No registered users and 20 guests
