MUM Europe 2020
firebat
Wireless client Signal strength?
Fri Mar 16, 2007 7:06 am
Is there a way to monitor the wireless client signal strength from the AP? I see a table entry created for each wireless client that connects but I don't think it is static? This the first Mikrotik AP that we are adding to our network and most the clients will access it from their laptops directly (so no Miktrotik CPE to monitor). I'd like to monitor if the client is connected, signal strength (throughput I can get from a simple Queue).
firebat
Tue Mar 20, 2007 3:40 am
Normis/Uldis? :)
uldis
Tue Mar 20, 2007 12:26 pm
depends on how you identify which client is which.
firebat
Wed Mar 21, 2007 6:20 am
We are doing MAC authenication with Static IP assignment. How can you correlate that to the MIBs wireless table though? Entries are added/removed depending upon if a subscriber is connected. :?
GWISA
Re: Wireless client Signal strength?
Sun Aug 19, 2007 2:18 pm
Users browsing this forum: No registered users and 10 guests
