neutronlaser
Crap on HAP AC2
Fri Mar 08, 2019 1:54 am
Lasts like 2 days before crashing, fix
pcunite
Re: Crap on HAP AC2
Fri Mar 08, 2019 4:13 am
Perhaps a bad unit or config? I have one working well.
neutronlaser
Re: Crap on HAP AC2
Fri Mar 08, 2019 3:55 pm
What storage are you using? If USB, what exact model of USB stick?
Reinis
Re: Crap on HAP AC2
Fri Mar 08, 2019 4:51 pm
First of all, you should create a ticket with support by writing an e-mail to support@mikrotik.com describing the issue, how to repeat the problem and providing Supout.rif file from the device.
Without the Supout file, it can only be a guess as pcunite said. But you should first try to Netinstall the device before proceeding with anything else.
https://wiki.mikrotik.com/wiki/Manual:Netinstall
As the wiki page says: Always try using Netinstall if you suspect that your device is not working properly.
neutronlaser
Re: Crap on HAP AC2
Fri Mar 08, 2019 6:53 pm
lol
Users browsing this forum: No registered users and 13 guests
