Fires
Dude notification - maximum number of emails per time
Fri Mar 22, 2019 1:40 pm
Hi , it is possible to setup for example to send just one email notification in 10 minutes ? Because If some core switch dies it send notification for every device what is connected to that. Thanks a lot
geoffsmith31
Re: Dude notification - maximum number of emails per time
Sat Mar 23, 2019 10:49 am
On your network maps you can set up dependencies between devices. If a device is down then dependent devices are not monitored and therefore to not generate alerts while that "upstream device" is down. On the map, up top on the right, change from links to dependencies, to set up and to view dependencies between devices.
Users browsing this forum: No registered users and 8 guests
