cdiedrich
Forum Veteran
Forum Veteran
Nested functions in probes, numbers in custom fields
Wed Apr 03, 2019 10:19 pm
Hi all,
It looks like using nested functions in probes don't work as expected. Runnind the Dude 6.44 in a x86 instance (not CHR). 6.44.1 shows the very same behaviour.
These terms are working perfectly when being used individually in a function probe in the "available" line:
if(device_property("CustomField1")=device_property("CustomField2"),1,0)
ping(device_property("FirstAddress"))
Now we want this first probe to be dependent on ping - when the device is down, it has to be shown as down, no matter if the custom fields match.
This doesn't work:
if(and(device_property("CustomField1")=device_property("CustomField2"),ping(device_property("FirstAddress"))=1),1,0)
Nor does this:
if(and(if(device_property("CustomField1")=device_property("CustomField2"),1,0)=1,ping(device_property("FirstAddress"))=1),1,0)
It's always showing unavailable.
Using string_compare instead of a direct = didn't help either.
The fields contain two comma-separated numerical values (like 6.36 and 11,147)
when the fields are 6,36 and 11,147 the field comparison returns a mismatch as expected. But 6,36 and 6,48 doesn't. How this?
A bit background on this:
It's a large scale WiFi deployment, Custom1 contains our planned channels for two radio interfaces. Custom2 is fed externally with the current operating channels pulled from the controller.
We want to see where a mismatch occurs (i.e. AP turns orange on the map).
Any ideas on this?
Thanks,
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
Users browsing this forum: No registered users and 10 guests
