annh
Push logs from Mikrotik to Graylog Server
Wed Jul 10, 2019 12:11 pm
Please support me about remote logs in Mikrotik.
I have configured as the following images but it seems that my Graylog server did not receive any messages (logs) from my Mikrotik and I also tried to create some messages for it
Note: Graylog server and Mikrotik with the same timezone.
jvparis
Re: Push logs from Mikrotik to Graylog Server
Wed Jul 10, 2019 12:16 pm
Have you tried using the same port? The listening port at the server has to match the remote port in the RouterOS-syslog-config...
zandhaas
Wed Jul 10, 2019 12:17 pm
Your Graylog server is listening on port 2514 while your mikrotik is sending the logs to port 1514
karlisi
Wed Jul 10, 2019 2:57 pm
Are you also writing in Graylog forum? As already said there, first check if messages can reach graylog server at all and if port 2514 is open on the server.
Karlis
annh
Thu Jul 11, 2019 5:59 am
Yes, I have reconfig port to the same but it's still not working ?? I dont know if Graylog 3.0.2 accept plugin Mikrotik ??
karlisi
Thu Jul 11, 2019 8:18 am
Yes, logs from Mikrotik can be collected on Graylog.
Karlis
Users browsing this forum: No registered users and 8 guests
