edmondyjh
Unable to install dude server
Sun Jul 14, 2019 6:09 pm
Hi all,
I tried to upload and install dude server into my routeros in RB2011 , but i get error saying "it is not mips".... my router is 6.45.1 and i have dowloaded the dude server 6.45.1, so how do you install it?
spacex
Re: Unable to install dude server
Sun Jul 14, 2019 6:46 pm
Dude not support mips packet
edmondyjh
Sun Jul 14, 2019 6:48 pm
So how do i enable dude package in my routeros?
Dude2048
Sun Jul 14, 2019 7:33 pm
You don’t. Mipsbe is not supported.
Hoov
Mon Jul 15, 2019 4:17 am
What Dude2048 is telling you is that The Dude can only be installed on the hardware of the following types,
TILE devices;
ARM devices;
MMIPS devices;
RouterOS x86 installations;
RouterOS CHR environment
Your Router is on the type MIPSBE. The hardware will not allow you to install The Dude. There is nothing you can update to, or downgrade to or change that will allow you to run the Dude. Your hardware is just wrong.
edmondyjh
Mon Jul 15, 2019 4:54 am
Oh, thanks for the detailed information. I guess i need to change to a compatible router to support this dude.
Elans
Tue Jul 16, 2019 8:28 am
You may find useful and more detailed information in MikroTik wiki page if you are interested in The Dude v6 Installation:
https://wiki.mikrotik.com/wiki/Manual:T ... stallation
edmondyjh
Thu Jul 18, 2019 9:17 am
I have setup this solution prior to my RB2011 router for this dude,
1.I gotten a VPS
2. I have establish PPTP tunnels to the CHR for my RB2011 router.
3. I have Run the Dude on the CHR but it ask me for this part on port number
So anyone has any idea on what "port" should i put it to get it working? Many thanks.
Elans
Fri Jul 19, 2019 10:25 am
The Dude and WinBox must have the same port.
edmondyjh
Fri Jul 19, 2019 10:40 am
Yes, i have put 8291 as the port number, but not working as well. So what port number should i put in as?
jebz
Thu Jul 25, 2019 4:17 pm
You need to change the "Server" setting on your Dude client to the IP or name of your CHR with the Dude Server.
edmondyjh
Fri Jul 26, 2019 5:29 pm
I tried putting ip or name of the CHR but still not working,
Dude2048
Fri Jul 26, 2019 7:44 pm
Go to users under sytem and check the permission of the full group. Admin should be a member of the full group
sid5632
Fri Jul 26, 2019 10:51 pm
It's kinda irrelevant when you can't get a TCP connection, doncha think?
Did you not see the 10061 error?
Users browsing this forum: No registered users and 4 guests
