alfred998
Link Label on the foreground
Wed Aug 21, 2019 8:31 pm
In my map the links (lines between computer and switch) cover label, so that I have to click on that specific link to see at what speed the computer is communicating. Is there a way do determine the showing order so label is above the link line ?
Elans
Re: Link Label on the foreground
Fri Aug 23, 2019 7:54 am
No, there is no such option. You may try to change "device" size if that somehow helps you.
alfred998
Sat Aug 24, 2019 10:33 pm
Yes, did that. I understand that devices take priority over link labels, but the links themselves, being simple lines, shouldn't cover labels where you can see the device network usage.
Users browsing this forum: No registered users and 4 guests
