isoplayert
snmp probe compare the oid lookup value
Sat Sep 07, 2019 12:56 pm
hello
fast question is " is it possible to compare oid lookup value instead of its integer value in SNMP probe ? "
the full story below :
i am using the dude to monitor many devices of my network including the UPS , and am using telegram api for notifications to inform me of the probe status
i am monitoring the following OID 1.3.6.1.2.1.33.1.4.1.0 which is an integer
in the appearance lable i put
status:[oid("1.3.6.1.2.1.33.1.4.1.0")]
and the output is "status:normal (3)"
i defined an SNMP probe to compare the value of the above oid if it is equal 3 or not
when the service is not equal 3 it is considered as down and i get a telegram notification says
"Service UPS.status on rackUPS is now down (statement 5 == 3 not true)"
instead of this , i want to compare the lookup value instead of the integer value in the probe and see if it is equal "normal"
so when i get a notification it would say "Service UPS.status on rackUPS is now down (statement onbattery == normal not true)
and so back to the first question is it possible to compare oid lookup value instead of its integer value in SNMP probe ? if not do you agree to add this feature in the dude server ?
geoffsmith31
Re: snmp probe compare the oid lookup value
Sun Sep 22, 2019 2:25 am
You'd be better off to write a function probe to get the solution you want rather than the auto-created probes that just do the value compare as in your example. Look in the Probes thread there are heaps of examples about how to do this.
Users browsing this forum: No registered users and 8 guests
