ptsip
Custom tools in Dude!
Fri May 04, 2007 5:42 am
If possible, pls a wishlist for custom tools for device, such as Remote Desktop connection, VNC Viewer, Radmin, etc.
Currently, from tools only: WinBox, Telnet, etc.
Thx.
firebat
Fri May 04, 2007 7:38 am
Please add this request to the Wiki Feature request page. See Sticky link at the top of the forum.
miko5881
Feature is already there
Fri May 04, 2007 3:10 pm
You can already do this. Just double click tools on the left and you can add all the custom tools you want. I have them for remote desktop, VNC, SSH, and a few custom URLs. You may have to find out how the commands work though. with vnc you can just put
vncviewer [Device.FirstAddress]
but for remote desktop you have to use
mstsc /v:[Device.FirstAddress]
ptsip
Mon May 07, 2007 7:22 pm
Miko:
Thx u so much, it works perfectly.
CR24
Re: Custom tools in Dude!
Fri Jul 28, 2017 2:44 am
Is it possible to send a terminal command with a custom tool? I get an error no matter what command I try to push.
Example: "/system reboot" (Yes I know there is a reboot option this is just an example)
eriitguy
Fri Jul 28, 2017 9:22 am
CR24,
/system reboot
Command/Tool you defined is started on your local PC.
If you want to run a command on remote device from Dude, you may try:
plink.exe [Device.FirstAddress] -P 22 -l [Device.UserName] -pw [Device.Password] "/system reboot"
Thank you!
CR24
Fri Jul 28, 2017 11:48 pm
Same error "The system cannot find the file specified."
eriitguy
Sat Jul 29, 2017 11:48 pm
CR24,
Dude client should be able to run plink.exe, it should knot full path to it.
For more information, please see The_Dude_v6/Tools
Thank you!
CR24
Sun Jul 30, 2017 12:05 am
Can you tell me how to setup a proper SSH tool? Ive been trying this.
ssh [Device.FirstAddress] -l [Device.UserName] -pw [Device.Password] "/system reboot"
eriitguy
Sun Jul 30, 2017 1:10 am
CR24,
1. Download plink.exe https://www.chiark.greenend.org.uk/~sgt ... atest.html
2. Place it in desired location, for example in C:\Tools
3. Create a custom tool:
C:\Tools\plink.exe [Device.FirstAddress] -l [Device.UserName] -pw [Device.Password] "/system reboot"
You also may copy plink.exe in Dude client folder and in such case you can use it without full path.
Thank you!
CR24
Sun Jul 30, 2017 1:24 am
Just did this, still getting the error, grr.
C:\Program Files\PuTTY\plink.exe [Device.FirstAddress] -l [Device.UserName] -pw [Device.Password] "/system reboot"
CR24
Sun Jul 30, 2017 1:31 am
made a folder C:\DudeTools and now its working. Thanks for your help.
CR24
Sun Jul 30, 2017 2:01 am
One more thing. Is there an argument to have plink run silently?
sid5632
Sun Jul 30, 2017 3:15 am
Not exactly suprising is it, since you have a space between "Program" and "Files" ?
CR24
Sun Jul 30, 2017 3:18 am
Yeah I noticed "Files" was in purple so I made a new folder and it worked. Guess ROS/Dude doesn't like spaces in paths.
eriitguy
Sun Jul 30, 2017 11:25 am
CR24,
Patch with spaces should be quoted:
"C:\Program Files\PuTTY\plink.exe" [Device.FirstAddress] -l [Device.UserName] -pw [Device.Password] "/system reboot"
sid5632
Mon Jul 31, 2017 9:56 pm
Of course it doesn't. How would it know?
A space is used as a separator between the various parameters, so it's perfectly obvious that you can't use one in a path name.
Blame those idiots at Micro$oft for the stupidity of putting spaces in path names.
Users browsing this forum: No registered users and 8 guests
