sparkle
3.0 beta 6 : Outages and Services appear empty
Wed May 16, 2007 1:51 pm
Hello
I run the beta 6 on a win xp machine . The upgrade path has been long for me (i run thedude since 2.0 beta 9) and this is the first bug that realy bothers me : after upgrading to the latest beta version if i open Outages and Services from the links in the left menu i don't see any entries in them. If i navigate to a device and see the properties of a service on it (let's say a vpn tunnel on a router) the outage events appear ok. Everything else runs fine. Any ideas ?
ceesco53
Fri May 18, 2007 4:26 pm
I am also experiencing empty outages and services, when I know last night I had a flapping Trango 900 AP and saw nothing in the outage history today.
Also am using 3 beta 6. This problem has been known ongoing since 3 beta 5 at least.
Minollie
Mon May 21, 2007 11:59 am
Hi guys,
I've the same problem here.
Sometimes it's just a matter of changing the view to 'all' Probes instead of 'Virtual memory' which appears to be the default setting for some weird reason..
As workaround I close the panel, then reopen it again which usually effective for our environment.
I hope Mikrotik solves this issue asap and.. change the default to 'all' devices which seems to me as a more obvious default then 'Virtual memory'.
Regards,
Minollie
sparkle
Haha
Mon May 21, 2007 4:13 pm
I'm so stupid : for me that's the problem also, the view defaults to the type "time" which is empty of course. If I select "all" then it displays ok. It's still a bug but i can live with that ....
itguy
Re: 3.0 beta 6 : Outages and Services appear empty
Thu Jun 07, 2007 8:50 pm
fyi: the dude v3b6 defaults to "ssh" probe in the outages pane.
Anyone have any experience editing the XML if that is something that can be changed via export/edit/import?
Cheers!
Users browsing this forum: No registered users and 14 guests
