christiaanlouw
My Dude Time does not seem correct
Tue Apr 21, 2020 10:10 am
Setup:
CHR 6.46.5 on Cloud VM.
Dude V6.46.5 on the CHR.
My RouterOS has the correct time based on GMT+2 using SNTP.
My graphs on the dude show the correct time.
My issus is that the reconnect time on RouterOS connections seem to be stuck at GMT+0.
Attached is an example.
You can see my time on the History graph is 08:48:50.
Then you see on teh RouterOS STatus it says reconnect at 07:36(Remember to remove a 30 Min period as that is my Routeros Reconnect Time - 30 Minutes)
teslasystems
Re: My Dude Time does not seem correct
Sun May 17, 2020 12:07 pm
Same problem. The time zone is not taken into account, it shows GMT+0 time.
christiaanlouw
Sun May 17, 2020 3:07 pm
I hope someone can assist with this.
Users browsing this forum: No registered users and 6 guests
