Since the last upgrade to v6.47, my Dude client crashes on a number of devices when I mouse over them in the Map view (charts start to appear and then client disconnects and starts reconnecting)
The same thing happens with when I try to view those device's details / settings screen -- Other devices are clean and work normally.
It appears to be related to some of the device's recorded chart data, because if I go into the "services" view, so no data is enumerated, and remove all the services on the device, then rediscover the services, that device will be fixed and work fine (at least for a bit).
I tried taking a Dude backup and using the sqlite3 DB's "obj" INSERT statements on a clean, new Dude DB (as described in https://wiki.mikrotik.com/wiki/Manual:T ... _db_repair) to remove all of the historical chart data, but the problem returned shortly after, even with all the historical data removed and 'fresh' devices created in the DB.
I've also tried playing with the rollup values (Raw keep time / 10 min / 2hr / 1 day rollup times) but it doesn't seem to have had any effect.
I have used the Dude for about 4 or 5 years now, and used to have a lot of historical data and a somewhat developed configuration for my environment. But given the recent problems I'm considering finding other monitoring solutions. I already trashed the old backup, so historical data doesn't matter now, but I'd really like The Dude client to stop crashing, and to be able to continue using it normally, again.
