wirefoxy
Admin Password
Thu Jul 02, 2020 6:46 pm
I want to use the dude 6.47, but I don't know the admin password...
I try blank password not ok
I try admin not ok
I try my user password not ok
please help me...
krafg
Long time Member
Long time Member
Re: Admin Password
Mon Jul 06, 2020 6:09 am
If you forget your device password, you will need reset to default and re-configure it.
Regards.
If you want to know my network, you can find it here.
wirefoxy
Re: Admin Password
Mon Jul 06, 2020 12:08 pm
Regards.
thanks for your answer.
I don't speak about device, but The dude.
I install the dude and execute it for a first time and ask me a password, I try blank paswword or admin/admin but not functionning.
erlinden
Long time Member
Long time Member
Re: Admin Password
Mon Jul 06, 2020 12:12 pm
Have you tried the devices password?
First the problem, then the solution
wirefoxy
Re: Admin Password
Mon Jul 06, 2020 3:05 pm
you speak about thr computer where the dude is installated ?
karlisi
Re: Admin Password
Mon Jul 06, 2020 4:16 pm
Mikrotik, where Dude server part is installed.
Karlis
wirefoxy
Re: Admin Password
Mon Jul 06, 2020 4:51 pm
I use the dude the last time there are few years...
so now need router OS + the dude client for functionning ?
before I install the dude and connected with admin blank password and nothing else
erlinden
Long time Member
Long time Member
Re: Admin Password
Mon Jul 06, 2020 4:53 pm
Mmmm...not sure if I understand you correct, for using The Dude you have to:
- install The Dude server on your MikroTik (or RouterOS running) device
- install The Dude client to connect to your server
From the client you connect to the server (with the credentials of the MikroTik device).
Can you please explain what step is missing?
wirefoxy
Re: Admin Password
Mon Jul 06, 2020 5:04 pm
this step : "- install The Dude server on your MikroTik (or RouterOS running) device"
Before the dude can watching all server or devices... likes windows os, linux os, HP switch or cisco routeur etc... not now is watch only MikroTik ?
karlisi
Re: Admin Password
Mon Jul 06, 2020 5:10 pm
No, you can monitor everything as before. The only difference is, now Dude server can run on RouterOS only. It can be Mikrotik device or CHR virtual machine.
https://wiki.mikrotik.com/wiki/Manual:The_Dude
Karlis
wirefoxy
Re: Admin Password
Mon Jul 06, 2020 5:40 pm
I understand better...
I see this : "To use RouterOS after the free trial, a license key is required" now is be longing not free ?
I don't understand very well how install... RouterOS
In 5 years all change...
karlisi
Re: Admin Password
Tue Jul 07, 2020 8:30 am
If you are speaking about CHR, you can use free version without registration, the only restriction is -
The free license level allows CHR to run indefinitely. It is limited to 1Mbps upload per interface.
https://wiki.mikrotik.com/wiki/Manual:CHR#free
Karlis
Users browsing this forum: No registered users and 13 guests
