djansen
Unable to Monitor Chateau (RBD53G-5HacD2HnD) Device (ROS v7.0beta8) from Dude (ROS v6.45.8)
Fri Jul 24, 2020 10:39 am
Hi Team.
I use the Dude server for monitoring my clients routers and networks.
I have deployed my first Chateau (RBD53G-5HacD2HnD) to a new site today (is running stock from factory ROS v7.0beta8).
I understand device is running Beta software - it will not be the end of the world for me if I cannot get Dude monitoring working on this device.
When you add the device in Dude you get the following messages (RouterOS Status):
"handshake timed out (6) (6), next attempt at ....".
"connection closed (6), next attempt at ...".
SNMP is working.
I feel that this is because the Dude server is running a lower version of ROS - therefore incompatible with ROS v7.0beta8.
The latest Dude server available is v6.47.1 (stable) or v6.48beta12 (testing).
Is there a version of Dude server that can talk with ROS v7.0beta8?
Thank you!
Dan
normis
Re: Unable to Monitor Chateau (RBD53G-5HacD2HnD) Device (ROS v7.0beta8) from Dude (ROS v6.45.8)  [SOLVED]
Fri Jul 24, 2020 10:45 am
As you observed, there are newer Dude versions available than 6.45. The authentication method was improved lately. I suggest to upgrade Dude as well.
djansen
Fri Jul 24, 2020 11:01 am
Hi Normis,
Thank you for your response!
I have now upgraded my Dude Server to ROS v6.47.1 and can confirm that it is now able to connect and monitor my Chateau.
Great work!
Dan
Users browsing this forum: No registered users and 7 guests
