alexspils
Dude 6.47.1
Fri Jul 31, 2020 2:15 pm
Hello!
We have strange problem after update from 6.45.2 to 6.47.1
Dude client(6.47.1) freezes when trying connect to dude server on "getting stuff" on 2 windows 10 PC.Turning off firewall, antivirus does not help
It can be resolved by connecting to other dude server(6.47.1), disconnection and connection to this server
Someone have this problem?
floaty
Re: Dude 6.47.1
Fri Jul 31, 2020 11:24 pm
Had some spooky moments with the dude myself ... you made quite a step from 6.45.2 to 6.47.1 ...
Migrating a database between software-versions is probably not the most beloved homework for a developer.
Not shure whether the amount of the data is worth the effort and if you have a db-backup ?
I would always include at least the first and last release from every inbetween-release-train in my upgrade-path. ... Just my opinion, couldn't give a reasonable cause ... I call it best practice.
But maybe you can try to change some db-items in your migrated DB, when you were able to connect after the session to the "native" 6.47.1-DB ... this may rectify things, if there are odds ... maybe.
The golden way (again: in my opinion) would be to switch back to 6.45.2 -> 6.45.9 -> somewhat 6.46.x -> last of 6.46 -> 6.47.
Every release comes with fancy new features ... also for the dude ... maybe with a new column in a table or a brand new table ... such stuff !? ... you see my point !?
You skipping releases, can have quirky results ( ... and you have such ... that may or may not be related ... to this fairy-tale)
Just test the writing thing ... it isn't helpfull & and you have a backup: try yoda's soft.migration ... or just build your dude from scratch :shock:
Let us know what have worked for you ( ... and if you liked it ... or not : )
We know what happens to people who stay in the middle of the road. They get run over.
alexspils
Re: Dude 6.47.1
Sat Aug 01, 2020 11:45 pm
i can repeat this bug only on windows 10 x64.seems it not ROS or dude server bug but windows client bug
Mikrotik team, can you reproduce it?
neutronlaser
Re: Dude 6.47.1
Wed Aug 19, 2020 6:01 pm
Wat
nikc
Re: Dude 6.47.1
Wed Aug 19, 2020 6:24 pm
Does running as administrator help ?
alexspils
Re: Dude 6.47.1
Thu Sep 03, 2020 4:31 pm
no, it does not help
Users browsing this forum: No registered users and 18 guests
