CoUL
[Device.Name] as an argument
Sun Aug 23, 2020 11:06 pm
[array_element(oid_column("1.3.6.1.2.1.2.2.1.1"),array_find(oid_column("1.3.6.1.2.1.2.2.1.2"),"sfp-sfpplus1"))]
[array_element(oid_column("1.3.6.1.2.1.2.2.1.1"),array_find(oid_column("1.3.6.1.2.1.2.2.1.2"),"[Device.Name]"))]
How to make it work?
The first option works
The second is the same, but the name of the interface (sfp-sfpplus1) is written in [Device.Name]
hAP, LHG, mANTBox, mAP, NetBox, NetMetal, PowerBox, PWR-Line, QRT, RB9xx, SXTsq, cAP, hEX Lite, RB4xx, wAP, BaseBox, DynaDish, RB2011, SXT, Groove, hAP mini, hAP lite, CRS3xx, CCR, RB3011, CHR, X86
RouterOS 6.45.9 (Long-term) | WinBox 3.27 (64-bit)
lebowski
Re: [Device.Name] as an argument
Mon Aug 24, 2020 7:06 pm
I am not exactly sure what you are trying here but Device.Name is a built in function that returns 1.3.6.1.2.1.1.5.0, the system name, would that work?
The function dev_name is exactly
if(string_size(oid("iso.org.dod.internet.mgmt.mib-2.system.sysName.0")),oid("iso.org.dod.internet.mgmt.mib-2.system.sysName.0"),"ghosting")
It looks like you are trying to find device.name in the oid 1.3.6.1.2.1.2.2.1.2 so I can't test since I don't have a system where the interface is the same name as the device name but it might work like this.
[array_find(oid_column("1.3.6.1.2.1.2.2.1.2"),dev_name())]
Let us know.
Joe
lebowski
Mon Aug 24, 2020 8:04 pm
[array_element(oid_column("1.3.6.1.2.1.2.2.1.1"),array_find(oid_column("1.3.6.1.2.1.2.2.1.2"),dev_name()))]
If that doesn't work, it is not possible...As far as I know.
CoUL
Mon Aug 24, 2020 8:09 pm
I thought so, but I wanted the opinion of an expert ... :). It's a pity it would greatly expand the possibilities of The Dude.
Thanks for the help!
geoffsmith31
Sat Sep 12, 2020 8:57 am
Have you tried device_property("Name") to return the device name?
I'm running version 4b3 on a Windows server and am using device_property("CustomField1") and device_property("CustomField2") to extract device information for use as parameters for some function probes.
Users browsing this forum: No registered users and 24 guests
