MUM Europe 2020
jacoblydon
DUDE Discovery
Wed Jun 27, 2007 7:43 pm
How can I stop my Dude from discovering a network cloud? I select the discovery tab and uncheck add links and networks, but it still seems to discover these networks and links. My only option at this point is to keep deleting the cloud. This dicovery really clusters my network diagram. Any suggestions?
bryanstein
Re: DUDE Discovery
Wed Jun 27, 2007 9:06 pm
Make sure you only have 1 autoscan network in the setting box or make sure you have unchecked the appropriate links on ALL autoscan networks. Go to the map and click settings then do as you did before. I'm pretty sure you have a rogue autoscan network that you aren't disabling the links and network on. You can also remove the label from the network map element. It gets really small then...just right click it-go to appearance-click the label drop down box and delete everything inside and you'll get this tiny cluster. Change it to oval if you want it smaller
jacoblydon
Re: DUDE Discovery
Mon Jul 02, 2007 4:50 am
Thanks. I will try that.
Users browsing this forum: No registered users and 13 guests
