tomislav91
change passwords of the devices
Wed Jul 28, 2021 11:58 am
is it possible to change all password or username of all devices somehow or must be manual?
normis
Re: change passwords of the devices
What devices do you mean? MikroTik routers?
tomislav91
Wed Jul 28, 2021 1:06 pm
Yes
rextended
Wed Jul 28, 2021 1:37 pm
The section is The Dude, but your question is too vague.
You talk about The Dude Device Settings or the remote devices displayed on The Dude?
If you ask that question, your knowledge can be valued and the reply can be:
All manual or pasting something on CLI, but still device-by-device.
But if your question is how change all the password or username (by group or all togheter) on The Dude Device Settings,
simply on Devices select one or more devices and after selecting "Device Settings" you can change the various field.
The unchanged are keep like before, and the changed are aplyed on all Dude Device Settings selected on that way.
But are set only on Dude Devce Settings, not on remote routerboards
tomislav91
Wed Jul 28, 2021 7:53 pm
i disabled admin user on my routers and wanted to somehow change it automation on dude, instead of change all 500+ devices manualy, but it seems dude dont have that kind of option
rextended
Wed Jul 28, 2021 7:57 pm
Your reply is vague...
Again:
You want change inside The Dude the saved username and/or password on displayed Devices
OR
you want change username and/or password on the remote devices displayed on The Dude?
tomislav91
Thu Jul 29, 2021 1:04 am
Again:
OR
when i click tools-winbox to open me with new credentials...
I already changed username/password on remote routers via some scripts.
So when support want to open now router from dude, they cant, cause stored username for all routers was admin, i can change it, double click and on the right change username...But why i cant do it auto
rextended
Thu Jul 29, 2021 1:20 am
On post # 4 I have already provided the instruction for do that, read and understand:
viewtopic.php?f=8&t=177166#p869620
tomislav91
Thu Jul 29, 2021 7:05 pm
yes yes understand for changing user and pass, tny
what about port?
If I change to some different instead of default? How can i change it in dude when open winbox to add that another port to address
rextended
Thu Jul 29, 2021 7:10 pm
Can not be defined on device property,
add more tools / WinBox Function for each port required
call it WinBox, WinBox 48291, etc.
Original:
winbox.exe [Device.FirstAddress] [Device.UserName] [Device.Password]
Modified for use port 48291:
winbox.exe [Device.FirstAddress]:48291 [Device.UserName] [Device.Password]
tomislav91
Sun Aug 01, 2021 1:08 am
Original:
where can i add those funcionts? where you enter this
Users browsing this forum: No registered users and 12 guests
