mellerbeck
Make tool, copy to all computers, possible?
Wed Aug 06, 2008 9:17 pm
and then apply it to all machines, is there an easy way to do this?
-Michael
normis
Re: Make tool, copy to all computers, possible?
Thu Aug 07, 2008 9:12 am
copy what exactly?
mellerbeck
Thu Aug 07, 2008 5:29 pm
Sorry, you're right that wasn't very specific. So, on the local map you can right click on a computer, go to settings, then the tools tab, then I hit the plus to add a tool. In my case its for UltraVNC then I hit OK. Well now I have that tool for that computer but I want the VNC tool to be able to be used on all of the computers!
sytex
Trainer
Trainer
Thu Aug 07, 2008 5:38 pm
"Contents" menu on the left side.
The second line is "Tools" dubleclick.
Red Plus, then add the tool.
Now you created a tool globaly for all the devices...
OR:
"Contents" menu again, select Devices. Then Select Types tab. You can create a custom device type (computers), the double click it. There will be a tool tab, where you can specifi custom tools for these device types. Now you have only to do: change the computer's types (on the device) to computers.
I hope this helped
mellerbeck
Thu Aug 07, 2008 6:09 pm
Yes, thanks a bunch! That does the trick!
Users browsing this forum: No registered users and 20 guests
