jkjjumba
Link Utilisation
Fri Aug 08, 2008 2:32 pm
Hi all,
Just downloaded and installed Dude.
I have done my topology manually together with the links. Unfortunately, I cannot see the Link utilsation (TX and RX) on the links. I can telnet and ping all the links, but nothing like utilisation on each link though I can see RX and TX without any info.
Your help will be highly appreciated.
Regards,
Joseph Jjumba
pekr
Re: Link Utilisation
Mon Aug 11, 2008 12:37 pm
Should be rather easy - double click the link. You will see rather simple dialog box. Choose appropriate "device". Then select "mastering type" as "routerOS". Then you will be albe to select "interface".
-pekr-
Users browsing this forum: No registered users and 18 guests
