CGirardy
SOLVED in RC1 : Attaching a Network Scan to a particular Map
Tue Aug 26, 2008 1:39 pm
I would like to know if there's a way to attach a subnet to a map and scan that subnet in this map only.
I have 40 different subnets.
I have created 40 different maps
I would like to attach a subnet to a map so that I can automatically refresh a map with the new devices that could be discovered in this subnet.
Right now, it puts every devices from the 40 subnets in every map I have created...
I hope my request is clear enough.
PLEASE... Release source code to the community and start developing The Dude again....
PLLLLLLLLLLLEEEEEEEEEAAAAAAAAAASSSSSSSSSEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE (big cry for help :))
lebowski
Re: Request : Attaching a Network Scan to a particular Map
Thu Aug 28, 2008 5:58 pm
Yeah you just have to be very careful that when you add a subnet to a new map that you never edit that subnet from the wrong map... What a pain. I don't know if you go back to the correct map for that subnet and edit the network if that repairs the incorrect association. I don't want to test it since I have a good start. They should just fix it.
Is there a place to post bugs?
CGirardy
SOLVED - Request : Attaching a Network Scan to a particular
Tue Sep 02, 2008 7:16 pm
This problem is solved in RC1.
You can finally scan for a specific subnet on a specific map :)
Users browsing this forum: No registered users and 13 guests
