CGirardy
SOLVED : Looking for a tool to use Wake-On-Lan...
Tue Aug 26, 2008 1:53 pm
I'm looking for a Wake-On-Lan tool that can work with TheDude.
I'm using Wolcmd but it doesn't accept a MAC address with : in it (only xxxxxxxxxxxx and not xx:xx:xx:xx:xx:xx)
I've tried mc-wol but it doesn't work for me
Does anyone know a good command line tool that can work please or a way to remove the : in the mac address before passing it to Wolcmd ?
PLEASE... Release source code to the community and start developing The Dude again....
PLLLLLLLLLLLEEEEEEEEEAAAAAAAAAASSSSSSSSSEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE (big cry for help :))
brakimienia
Re: Looking for a tool to use Wake-On-Lan...
Wed Aug 27, 2008 12:46 pm
Try running wolcmd via batch file (i.e. wol.bat) with code below
@echo off
set MAC=%1
set MAC=%MAC::=%
wolcmd %MAC% %2 %3 %4
Regards
CGirardy
Wed Aug 27, 2008 1:14 pm
Thanks a lot,
Works well if I type it in a DOS box but doesn't work from TheDude.
Here's the command line I have created :
C:\Softs\wol\wol.bat [Device.FirstMacAddress] [Device.FirstAddress] 255.255.248.0
But it doesn't seem to work when started from TheDude.
Any idea ?
EDIT : Found the problem :
It doesn't accept the [Device.FirstMacAddress] variable
Using the [Device.MacAddressesColumn] variable works.... :D :D :) :D :lol: 8)
That's really great.
Thanks a lot for your help
brakimienia
Wed Aug 27, 2008 1:21 pm
Thanks a lot,
Any idea ?
Are you using full path to the wolcmd program in .bat file?
CGirardy
Wed Aug 27, 2008 1:33 pm
I have also added the full path to the wolcmd program in the batch but it's the [Device.MacAddressesColumn] variable that did the trick :)
Thanks for your help
marushka
Re: SOLVED : Looking for a tool to use Wake-On-Lan...
Thu Sep 03, 2009 1:27 pm
I don't excatly understand that wol.bat file, can you please give an example. I'd like to ping address 10.2.100.2 for example, mac od the interface I'd like to ping is: 00:0C:42:14:1B:0F.
I'm not sure about the sintax, can you please show me the command.
Thank you!;)
If you can't convince them, confuse them!
Users browsing this forum: No registered users and 14 guests
