msorensen
Router Logs full of user log in & log out records
Sat Aug 30, 2008 10:06 pm
OK.... I've searched the forum and can not find it... I'm sure that there is a thread on it ;-)
Running Dude 2.2 on the WinXP machine...
Some of my mik RBxxx routers, sometimes have a ton of "system info account user xxxx logged in from [dude ip address] via winbox" log entries....
It immediately logs out, then back in a few minutes later, log in, log out, in, out, in out....
Why is this happening? and how do I stop it.... router logs are full of this garbage....
I'm assuming that the issue is with the dude... perhaps it is a winbox issue....
sergejs
Re: Router Logs full of user log in & log out records
Mon Sep 01, 2008 11:37 am
Unset 'MikroTik RouterOS' for the monitored devices in Dude settings.
Then there will be not notifications about login from Dude address.
msorensen
Tue Sep 02, 2008 7:33 pm
That definately stopped the log-in, log-out activity.... Thanks
Curious as to why?
What purpose does checking "Router OS" accomplish?
Why does the Dude log-in and log-out when that attribute is checked?
normis
Fri Sep 05, 2008 3:37 pm
there are some RouterOS parameters you can control and monitor from within Dude. you can use dude as a simple winbox too. To get these values Dude has to log in
miahac
Long time Member
Long time Member
Sun Sep 07, 2008 5:59 am
is there a way to keep the dude session open rather than have loads of logins... Or to only login when data requiring login is collected?
Network Consultant in Wichita, KS
Vigor
Fri Nov 21, 2008 2:06 am
I'm facing a similar problem with a MikroTik v3.16 router. I'm using WinBox Loader v2.2.10 in order to login to router's IP 10.3.36.1 from my PC which sits on IP 10.2.23.1. BGP is the routing protocol inside our network. By having a look into remote router's Log, it appears that my user account is logged in from another IP (10.2.15.1). Could you please have a look at it?
I hold no installation of Dude inside my network (10.2.23.0/24) and at the moment of the successful logins it could only be me logging in. No one else has access (knows the passwords to that particular router), so it couldn't be someone else logging in at the very same time. :shock:
nov/20 23:22:36 system,info,account user admin logged out from 192.168.1.10 via
winbox
nov/20 23:38:08 system,info,account user admin logged in from 192.168.1.10 via w
inbox
nov/20 23:39:20 system,info,account user admin logged out from 192.168.1.10 via
winbox
01:06:21 system,info,account user admin logged in from 10.2.15.1 via winbox
01:07:52 system,info user admin changed by admin
01:07:58 system,info,account user admin logged out from 10.2.15.1 via winbox
01:08:14 system,info,account user admin logged in from 10.2.15.1 via winbox
01:09:41 system,info user Vigor added by admin
01:09:44 system,info,account user admin logged out from 10.2.15.1 via winbox
01:10:00 system,info,account user Vigor logged in from 10.2.15.1 via winbox
01:59:25 system,info,account user Vigor logged in from 10.2.15.1 via telnet
I know what I know and that's all I know.
What I don't know I'll find out.
rebellion
Sat Nov 22, 2008 4:59 pm
maybe it is discovering in dude?
Users browsing this forum: ponchocb and 23 guests
