alex_rhys-hurn
has anyone tried to install rc2 on ros x86 v3.10?
Tue Sep 09, 2008 3:34 pm
I downloaded the routeros independant package from the website, ftp it to my core router on x86 and then reboot the system...
no deal. the package does not install.
Can anyone tell me how to do it?
BEst,
Alex
normis
Re: has anyone tried to install rc2 on ros x86 v3.10?
Tue Sep 09, 2008 3:43 pm
you should try a newer ROS version
sytex
Trainer
Trainer
Tue Sep 09, 2008 4:40 pm
I've just installed it on x86, ROS 3.13, universal version dude package
alex_rhys-hurn
Tue Sep 09, 2008 6:34 pm
!! So what is the point of a routeros independant version of Dude if it doesnt run on all routeros....
I can upgrade my router to 3.11 but not beyond at this point until I am sure that the multiple processor and queue issues that were in 3.12 have been solved. Have they been solved in 3.13?
Regards
Alex
alex_rhys-hurn
Wed Sep 10, 2008 8:27 am
Hello.
Still not working.
I upgraded my x86 to ROs 3.13.
Then FTP the file dude-3.0rc2.npk to the router. Checked that the file size was the same on the router and on my desktop.
Then rebooted the router. It doesnt install.
Then I re-downloaded the dude file again to make sure its a good one and tried again.
No Go....
Suggestions please.
Rgds
Alex
normis
Wed Sep 10, 2008 9:04 am
check the log please, package should work on all versions
cybergold
Wed Sep 10, 2008 8:47 pm
seriously, what will the dude do for me when i install it in the router? how can it be accessed from winbox?
i have always used it on a windows based pc.
normis
Thu Sep 11, 2008 9:09 am
the dude client will be able to connect to it, and use it as an agent to look at the network behind your router.
sergejs
Thu Sep 11, 2008 4:33 pm
I have tried Dude on RB600 3.10, it's working. I'll try to find x86 box somewhere and try to test the same.
alex_rhys-hurn
Thu Sep 11, 2008 7:38 pm
Ok, so following the suggestion to look at the log file (and I deserve a fine for not thinking of that myself, sorry) the log file says the following:
system warning: omitting package dude-3.0rc2: newer package dude-3.13 is already installed
So there is some problem there.
Any ideas? Can I just rename the package to like dude-3.14 and try again?
Rgds
Alex
sergejs
Fri Sep 12, 2008 8:18 am
Alex,
system package uninstall dude,
then install dude-3.0rc2
Users browsing this forum: No registered users and 8 guests
