cinatus
dude-3.1.npk is broken!
Tue Jan 13, 2009 11:15 pm
I tried using the dude-3.1.npk file on a new ROS 3.18 server and it says that the package is broken.
airstream
Re: dude-3.1.npk is broken!
Wed Jan 14, 2009 12:02 am
try downloading the package from Mikrotik again and uploading it to your router.
Keep tryin' its bound to work!!
ROOT@COSMOS> Reality.sys corrupted -- Reboot Universe (Y/N)?
>_
iam8up
Sun Jan 25, 2009 8:33 am
Worked on my 3.19 x86 box
wifi45
Wed Feb 18, 2009 6:10 am
I'm having the same problem trying to put dude 3.1 on a mitrotik 433 with ROS 3.20.
Have downloaded it from MT multiple times with same result.
Ikatsu
Wed Feb 18, 2009 5:01 pm
I have the same problem, using the PowerPC package, 3.20 version. It only use 1.6 Mb.
normis
Thu Feb 19, 2009 9:00 am
try to use some download manager, as the package is fine
dasiu
Trainer
Trainer
Thu Feb 26, 2009 11:56 pm
There is definitely a problem: RB433, ROSv3.20, Dude v3.1 - downloaded it 2 times, still thinks that the npk is broken.
Is there anyone, who succeeded in installing Dude package with a configuration like that?
clink
Sat Feb 28, 2009 12:08 pm
There are a problem for RB433AH with dude package 3.1 - We have an old download npk file for mipsbe which is 8.79 mb and now if we download the same file it has been cut down to 5.79 mb. size.
We are able to install the big file, but it is just eating up the HDD space and memory, and we are only using our RB433AH as agents. we have tried downloading the npk file 5.79 mb. 6 times from different ISP lines and to different pc's and when we try to install it on our RB533AH boards, we just get the message: RB-Broken package dude-3.1-mipsbe.npk
There are certainly something wrong with this package!
clink
Sat Feb 28, 2009 12:12 pm
Sorry forgot to tell you, that we are running RB433AH, ROSv3.20, Dude v3.1 and both npk package are named dude-3.1-mipsbe.npk (8.79 mb.) this one can be installed and the one which is able for download now is dude-3.1-mipsbe.npk (5.21 mb.) and can't be installed!
tomekmak
Tue Mar 03, 2009 1:36 am
There is a huge problem with http://www.mikrotik.com/download/dude/3 ... .1-ppc.npk
I just opened my brand new beauty RB1000, upgraded to 3.20, downloaded dude package from above - and i got in my log:
"broken package dude-3.1-ppc.npk"
I downloaded more than 15 times, from different computers and os (win xp, ubuntu, win2k) using firefox, ie, opera. Problem is always same...
I put loads of money into it, and now it's not working. Please help me asap.
/// EDIT ///
I checked:
.ppc package is only 598210 bytes
.x86 package is 8454267 bytes and on old pc-router works fine
QpoX
Tue Mar 03, 2009 2:02 am
MD5 file hash!
I use the PPC package with no problem!
Do people upload it with FTP or Winbox?
tomekmak
Tue Mar 03, 2009 2:57 am
Man, package from mikrotik webpage for ppc has 0.5MB, for PC 8.1MB , isn't there something wrong ?
QpoX
Tue Mar 03, 2009 3:43 am
Try this one... it works on my system! http://www.box.net/shared/m2tr543afa
numanx
Fri Apr 03, 2009 1:37 pm
hi i can`t install dude reason the log says "broken package dude-3.1.npk" please help me......
QpoX
Fri Apr 03, 2009 1:41 pm
Did you download the dude package from my link above?
numanx
Sat Apr 04, 2009 3:48 pm
but what happened with the package on the http://www.mikrotik.com ??????
LATER EDIT:......
IT ALSO DOESN`T WORK IT SAYS AGAIN IS BROKEN.
P.S. For a pc router os
normis
Mon Apr 06, 2009 1:34 pm
we will release v3.2 Dude soon, you can try with new package then. I don't know why it says broken, it works for me. Maybe you have cached the broken package in the browser or proxy?
Users browsing this forum: No registered users and 11 guests
