adamd292
string_compare problem
Thu Feb 12, 2009 5:45 am
If I set this as the label for a device:
[string_compare("dude","dude")]
[string_compare("notdude","dude")]
[string_compare("dude","")]
[string_compare("","dude")]
The description appears as:
4
7
4
0
This is not correct - string_compare says it returns 0 when the strings are the same/
I think there may be a problem - It is like string_compare is doing the same thing as string_size.
teslasystems
Re: string_compare problem
Sat May 18, 2019 8:02 pm
Looks like already 10 years passed, but I have the same problem now in 6.44.3 version. It should be fixed!
lebowski
Tue Jun 04, 2019 5:47 pm
The first post on the probe thread says to use -1 for false...
Cisco CPU
Type: Function
Available: if(oid("1.3.6.1.4.1.9.2.1.58.0")>0, 1, -1)
but -1 is true, try it...
[if(-1,"-1 is true","-1 is false")]
This incorrect information should corrected, anyhow why use -1 for false when 0 is precise unless you are passing a value to another function just use 0.
Great program but fixes are slow if at all.
Users browsing this forum: No registered users and 4 guests
