momi
The Dude time
Fri May 29, 2009 1:38 pm
maybe this was a topic earlier but i don't have time to read...but, how to adjust time and date on The Dude server...or on The Dude client...it always says it is 1st January...and time is always between 00 h and 23h :?
sergejs
Re: The Dude time
Fri May 29, 2009 4:16 pm
I guess you have Dude on the RouterOS, setup NTP client to get the correct clock settings on the RouterOS (or any other device you're using), then time should be correct. Correct time should be on the device, where Dude server is installed.
momi
Re: The Dude time
Fri May 29, 2009 5:34 pm
thank you sergejs for replay...our server is on PC Windows Server 2003 Edition and the problem is solved...the problem was that our server don't synchronize with windows time protocol but we chose another...
Percanta
Re: The Dude time
Tue Jun 09, 2009 3:44 pm
i have different time between dude and web dude
Users browsing this forum: No registered users and 9 guests
