soho
Not enough free space available
Sun Oct 25, 2009 3:49 am
When I try to Export the DUDE is displayed the message "not enough free space available".
As you can see the image but there is space, because I'm using a secondary media for the Dude.
In menu FILE, appear 0 byte for Dude... I'm not understanding.
The Dude is installed on a Mikrotik ROS x86 version 3.28.
Any tips?
soho
Re: Not enough free space available
Mon Nov 02, 2009 3:41 am
up
normis
Mon Nov 02, 2009 12:40 pm
what are you trying to export, can you show us a screenshot of that too ?
soho
Wed Nov 04, 2009 4:02 pm
I'm trying to export the settings of the Dude. See image attached.
lebowski
Wed Nov 04, 2009 4:36 pm
Find the syslog folder and clear out the logs then do an export. Change the settings for syslog and don't save as much...
soho
Thu Nov 05, 2009 1:55 am
thanks sweetdude, but not resolved ... erased everything that was in the Syslog and I could not export. The same error is show.
lebowski
Thu Nov 05, 2009 4:18 pm
Yeah that is crazy :(...
I am not running ROS so I can't do any testing... bleh.
Make a script to copy the dude folder to another folder?
soho
Fri Nov 06, 2009 4:09 am
not understand ... copy to another folder, why?
lebowski
Mon Nov 16, 2009 5:58 pm
Oh that would be another way to make a backup... Just a complete copy of the original folder.
Users browsing this forum: No registered users and 19 guests
