Martin9700
Uptime Probe
Thu Nov 05, 2009 11:15 pm
I'm trying to create a simple probe to monitor uptime. Either 1 for "up" or 0 for "down".
Using a Probe:
Type: Function
Agent: default
Available: if(array_element(ping("192.168.4.5"), 3)="ok", 1, -1)
Error: 0
Value: 1
Unit: <blank>
Rate: none
I just get a "down" probe all he time (Error field triggering). I've tried a few settings in "Available" like:
and
array_find(ping("192.168.4.5"), "ok")>0
But it always error's out and runs that line. I've even pasted the code above into the error line so I could see if I was working off of the right fields and it looks like I am.
Any assistance would be appreciated!
Morphology
Re: Uptime Probe
Fri Nov 06, 2009 2:02 pm
The Ping function itself returns exactly the opposite of what you want (-1 if Ping Fails), so to graph the System Down Times you would create a probe with the following elements:
Type: Function
Agent: default
Available: not(ping(device_property("FirstAddress")))
Error: ""
Value 1
unit <blank>
Rate: none
I've used ping(device_property("FirstAddress")) rather than hard coded the IP address because you can then apply it to any device whose up time you want to graph.
By all means replace this with ping("192.168.0.1") or whatever.
Morph.
Martin9700
Re: Uptime Probe
Fri Nov 06, 2009 4:11 pm
Hey Morph,
Unfortunately, that's not working either. I put your code in the available (I did want to make it more generic eventually, I was just working on making it work first) and I still get the error line executing.
I wonder if the Available line can't handle array's, but the error line can. Maybe I'll try a custom function that uses ping, but only returns one item.
Martin9700
Re: Uptime Probe
Fri Nov 06, 2009 4:30 pm
Ah, now I'm starting to get it.
The ERROR line is what actually creates the data. And non-error must return "" to generate the VALUE line. So:
Err: if(array_element(ping(device_property("FirstAddress")), 1)=0,0,"")
Value: 1
Light dawns on marble head........
Martin9700
Re: Uptime Probe
Fri Nov 06, 2009 4:34 pm
And the more I think about this:
Value: if(array_element(ping(device_property("FirstAddress")), 1)=0, 0, 1)
sady
Re: Uptime Probe
Thu Nov 26, 2009 9:16 pm
why you can't use standart ping probe? you want to straight line graph of you up/down periods?
Please, please, Open Dude Source! Pleaaaaseeeee!!!!!
Martin9700
Re: Uptime Probe
Mon Nov 30, 2009 4:12 pm
Exactly, just a simple "up" or "down" return (1, 0).
Users browsing this forum: mph1 and 29 guests
