MUM Europe 2020
LatinSuD
Wine compatibility?
Mon Jul 04, 2005 9:50 pm
Could it be made to work under wine?
Or else, is there a similar tool for linux, that allows to place hosts on the screen and watch ther alive status?
lastguru
Trainer
Trainer
Mon Jul 04, 2005 9:57 pm
it should work under the latest wine version.
International MikroTik Certified Trainer and Consultant form Latvia.
I do RouterOS Training and Certification worldwide!
skype: lastguru
avantwireless
Wine Compatability....
Wed Jan 18, 2006 8:34 am
:cry:
Will there be more work on Dude so that it's not completely crippled under Wine? Devices don't have names, there is no way to add links and so on and so on... Please some work on it under wine?
thank you...
uldis
Wed Jan 18, 2006 7:40 pm
Text on network maps is visible when using wine 0.9.4, maybe you should
upgrade.
What do you mean by not being able to add links? You should click on '+'
button, then 'Link', and then drag a line from one item to another. Please be
more specific about your problem. Note that operations causing network map to
redraw are pretty slow under wine so you should be patient when dragging a
line.
avantwireless
Wed Jan 18, 2006 7:50 pm
I am running a just installed 9.2 so I'll upgrade and try again...
thanks!
avantwireless
Thu Jan 19, 2006 4:34 pm
Ok, so now I am running 0.9.5 latest compiled code and now I can make links. BUT when looking at the maps from Dude run under wine on a Fedora 4 installation the boxes are all small and have no text in them. This is using remote to attach to the server, local attach fails. IF I look at the server from a dude on a windows system, the labels are all there, from the same server run under wine! Next I am going to remove all my wine configuration and start over. :cry:
uldis
Thu Jan 19, 2006 6:06 pm
It is important that you have some fonts in your
~/.wine/fake_windows/Windows/Fonts or whatever whatever directory you are
using for windows.
msttcorefonts package on debian contains some of windows default fonts
And if that still does not work you may want to run 'regedit' on your wine
computer and look for key
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Fonts
or
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Fonts
and enter some mappings from face name to font file name manually. Don't know
if that works, but 'theoretically' this is place where on actual Windows
computer is stored font face name to file name mapping, e.g installing new
font adds new entry in this key.
avantwireless
Thu Jan 19, 2006 6:15 pm
I tried it without and then with moving windows fonts into .wine/drive_c/windows/fonts. Fonts look normal, and I chose a font for the appearance out of the font chooser just in case. I am getting icons for the device in the box, but most importantly not getting text for the bandwidths on the links.. I have selected the info to be displayed and it all works fine from dude under windows... Just dude under wine... Same server in both cases, server running under wine... Also under wine the items ( device, subnet, link, etc...) are in a list whereas under windows they are icons to select. That struck me as strange...
Thanks for the help!
uldis
Fri Jan 20, 2006 11:43 am
Link labels on network map use different font for link labels than for item
labels. It uses Lucida Console by default. Maybe you should try changing it
by right clicking a link, then choose 'Appearance', then click on 'Font' and
choose some other font - for example the same that you are using for item
labels and you are sure that it works.
Remember that you can change appearance of all links at once (except those
that has been changed manually) by changing default font in global server
configuration. To do that you click on 'Settings' button besides 'Undo' and
'Redo', go to 'Map' tab, then click 'Link Appearance', then you will see font
setting that applies to all links.
avantwireless
Mon Jan 23, 2006 9:48 pm
Ok, so now we are running the latest 19 release. Tried changing fonts etc. Running Fedora 4 on all machines, latest wine, etc... No joy on text on anything with the client running under wine. With dudes.exe under wine and the client under windowsXP all is ok. Anyone with any ideas?
thanks!
djape
Sun Mar 19, 2006 3:23 pm
using for windows.
or
Just follow what uldis wrote and everything will work fine.
No problems running dude in wine here :)
I drink like a pirate and smoke like a hippie...
chrisd13
Mon Mar 20, 2006 11:00 pm
Slightly off the beaten track but I have always had strange problems with any version of fedora.
If the above procedure does not work with the fonts, I would try another *nix flavour.
hope ya get it fixed.
normis
Tue Mar 21, 2006 9:37 am
we will see what we can do to improve the wine compatibility
Users browsing this forum: No registered users and 7 guests
