rileonar
How to pass parameters to a function
Tue Apr 20, 2010 5:31 pm
does anyone know how to pass parameters to a function?
I'd like to write a single custom function (e.g.: disk_free_space) and pass to it a parameter, in order to use it into different probes using different values:
a) Probe: server_disk_warning
disk_free_space(2000)
b) Probe: server_disk_alert
disk_free_space(500)
In probe a) I would set the limit threshold to 2000 MB, in probe b) to 500.
Does anybody know if that's possible and eventually some sample to share the syntax to use into the function?
TKS.
gsandul
Re: How to pass parameters to a function
Wed Apr 21, 2010 11:51 am
Currently there is no way to pass params to function.
rileonar
Thu Apr 22, 2010 3:37 pm
Thanks for your answer. :(
I wonder how can I avoid writing hundreds of functions and probes, all identical except for silly parameters like disk label (C, D, /var....), threshold (100, 1000....) and so on.
Does anybody have ideas?
Many thanks in advance.
znet
Mon Apr 26, 2010 6:56 pm
How about writing a simple 'daemon' script running on the device that creates variables accessible via ros_command?
alangregory
Mon Sep 11, 2017 8:21 pm
Any news about this feature ?
geoffsmith31
Wed Oct 25, 2017 8:33 am
I'm also keen to be able to pass parameters into a function that I have written. It seems that this should be possible as many of the built-in functions can accept input parameters. Just that this capability is not exposed (or not documented) for user functions.
BlackVS
Wed Oct 25, 2017 10:40 am
Starting from 6.2 ROS supports passing arguments to custom functions:
https://wiki.mikrotik.com/wiki/Manual:S ... #Functions
Also global variables can be used to pass parameters.
geoffsmith31
Thu Oct 26, 2017 2:44 am
Post by BlackVS » 25 Oct 2017 17:40
I think what you are referring to here is ROS functions - Not Dude functions. If I'm wrong, can you please advise how to pass a parameter into a user created Dude function?
CZFan
Location: South Africa, Krugersdorp (Home town of Brad Binder)
Sat Dec 01, 2018 10:28 pm
Bump
MTCNA, MTCTCE, MTCRE & MTCINE
teslasystems
Sun May 17, 2020 12:00 pm
This topic is already 10 years old and nothing done. Very bad :(
Users browsing this forum: Baidu [Spider] and 21 guests
