blackpaw
"too many elements" on Service-Discover
Thu Aug 05, 2010 10:41 am
Hello
Can you help me with this error?
When I create a device manually and then click the "Discover" button to discover the services it has (interfaces, probes, etc...) I get the following error/warning in red letters at the bottom: "too many elements"
thanks in advance,
Andreas
life is one of the hardest
gsandul
Re: "too many elements" on Service-Discover
Thu Aug 05, 2010 12:26 pm
Hello, Andreas.
Do you rely need all those services IFindex_1.... IFindex_26 to be autodiscovered?
If not - disable autodiscovering for those services and this should solve the problem.
blackpaw
Thu Aug 05, 2010 1:45 pm
I kind of need this, yes... this is to automagically add a probe if a new device has been connected
However: When I do the discovery via the settings > general > auto scan I can narrow down the services to be probed to the ones that can physically exist on this device... but the "discover" button always seems to probe for them all. Guess I have to stop using it, then...
will it help if I check with wireshark/debugging?
Andreas
gsandul
Thu Aug 05, 2010 2:51 pm
You can stop auto discovering of services when you press discover button on the device properties, have a look at the picture
Users browsing this forum: No registered users and 8 guests
